Thumping noise from right front...
Old Jun 10, 2005 | 12:00 AM
C5 Freak's Avatar
C5 Freak
Default Thumping noise from right front...
when I go over a speed bump of a dip. This occurs at normal (slow) speeds, not just haulin azz. I hear a clunking noise & it feels like something is bottoming out.
Can anybody shed some light on this?
Old Jun 10, 2005 | 02:40 PM
pewterfrc03's Avatar
pewterfrc03
Cruising
already been through this one. check the sway bar endlinks they are loose thighten them down it will go away.
Old Jun 10, 2005 | 02:48 PM
b98's Avatar
b98
Had the same noise at high speeds, turn out to be my passengers pumping the rigth side brake pedal.
Old Jun 10, 2005 | 03:41 PM
babalu95's Avatar
babalu95
Default Have that problem too.
So far, I've already tightened the sway bar and relubed the bushings. Upon hearing the clunk again I took it to a FORD tech and he disvovered it was a inner tie rod end that needed replacement. He could physically move the tie rod with his hand. So much for GM techs who'd previously said there was nothing wrong.
Old Jun 11, 2005 | 09:17 PM
C5 Freak's Avatar
C5 Freak
Thanx for the 411. I'll give it a look see.
Old Jun 12, 2005 | 03:02 PM
leaftye's Avatar
leaftye
Are you bottoming out? I bottom out often, even if I'm cautious, but I have A&A frame savers so I don't have to sweat it as much.
Old Jun 12, 2005 | 03:15 PM
C5 Freak's Avatar
C5 Freak
The car itself doesn't bottom out, it just feels like a suspension component is hitting maximum travel.
Someone suggested checking sway bar end links & tie rods, so I crawled under the car earlier and it looks like the shock may be blown cause there is oil all over the swing arm and other components.
Now where is the DIY section on R&R for shocks?
Old Jun 12, 2005 | 08:41 PM
leaftye's Avatar
leaftye
It's on www.ls1howto.com. It's tied in with the spring replacement diy.
To Thumping noise from right front...
