Surging / Fast Idle....
Old Jun 12, 2005 | 02:47 PM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Default Surging / Fast Idle....
Just this past week my car has developed an idle issue.
When it gets warm it will surge a bit when stopped at a light.....idle will go as low as 600 and as high as 900. Never feels like it's gonna die.....idle just goes up and down. Also.....when I decelerate from the freeway to a stop of the off ramp, the car will initially idle at about 1100, then after 5-10 seconds will slow down to the correct idle.....then start with the surge thing again.
There are no codes........any suggestions?
Old Jun 12, 2005 | 02:59 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Check all intake connections for any sign of possible intake leak after the MAF. Check your ground connections as well.
Old Jun 12, 2005 | 03:18 PM
Ramsie C5's Avatar
Ramsie C5
mines doing the samething, I figured it was because its so damn hot lately
when I crank it up it will idle high, then once I start riding around it will get normal.
Old Jun 12, 2005 | 04:49 PM
X-ZZ4's Avatar
X-ZZ4
Dude......if you're ever in SoCal hit me up for a beer or something....you were right on the money!!!
I checked all my vacuum lines.....found a tear in the brake booster grommet. Replaced it and the car idles smooth as silk!
I was convinced it was gonna be some spendy sensor or something.....but nope....all of $1.99 fixed it!!!
Thanks for the suggestion!
Steve
Old Jun 12, 2005 | 09:14 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Glad you got it all fixed up!!
VR
Old Jun 12, 2005 | 09:38 PM
VT's Avatar
VT
I am having some surging/hesitation as well... Anyone have a list of vacuum lines? I may do a total swap, I just patched one do to a battery leak but this seams to be a recurring issue lately here on the forum...
To Surging / Fast Idle....
