throttle body bypass
Old Jun 10, 2005 | 01:09 AM
caster5303's Avatar
caster5303
Default throttle body bypass
What's the advantage of doing this low cost mod??????
Old Jun 10, 2005 | 07:11 AM
Dark-Knight's Avatar
Dark-Knight
Regretably there is no advantage to this mod, sugguest you save your money and time and try something else.
Old Jun 10, 2005 | 08:37 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
No advantage - but I did it anyway
Old Jun 10, 2005 | 08:59 AM
vettenuts's Avatar
vettenuts
If you work on your motor a lot, it is worth it just not to have to undo the cooling lines to get the throttle body off. As a performance mod, its not worth anything that I have ever seen.
Old Jun 10, 2005 | 09:53 AM
RPOZ16's Avatar
RPOZ16
Good point, we sometimes focus on the performance claims and forget the value of not having to mess with the lines when doing other work.
Old Jun 10, 2005 | 11:19 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
All it does is make your next engine work project easier in regards to moving the line, performance increase ain' going to happen.
Old Jun 10, 2005 | 11:43 AM
chriswtx's Avatar
chriswtx
I did it for $4. Go to homedepot and look by the compressors. There is a repair kit to repair 1/4" hoses. Cost $2.95 comes with a barbed connector and hose clamps. Then go to the autoparts store and buy 12" of 1/4" hose for $.96 and thats everything you need for under $4...
Old Jun 10, 2005 | 12:24 PM
Last C5's Avatar
Last C5
It cleans up the front of the engine. For just a few dollars I bought a length of hose, a length of ribbed hose cover, a clip to hold the hose cover to the back of the fan shroud, and two caps for the abandoned inlets. I ran the single length of hose and cover directly from the radiator to the manifold and pinned it to the fan shroud. It looks factory, minimizes the places it can leak, and gets it out of the way of everything else. (Now I'll get flamed for no pictures, but I'm just not that technologically advanced yet. :o )
Old Jun 10, 2005 | 02:45 PM
SPD KILZ's Avatar
SPD KILZ
The reason behind the coolant going in the tb in the first place is to keep the tb from sticking in cold weather. The coolant running through the hose would actually heat up the tb eliminating stickage. But in warm locations such as Texas you dont need this.
On my 02 Silverado it has actually worked in reverse. The tb blade kept sticking. I have a friend who is a Gm tech whom I told him about the prob and he told me to do the mod on the truck. Well 20,000 miles later and I haven’t had a problem since. Dont ask my why it worked but it did.
O and when i got the vette I did it to its tb as well just for prevention.
Old Jun 10, 2005 | 05:46 PM
robsvette's Avatar
robsvette
it never stuck on me during the winter months in NJ never for 5 years. i also got the fitting from home depot. i rather not have hot coolant pass through there even though it still will get hot.
Old Jun 10, 2005 | 07:29 PM
LoneStarFRC's Avatar
LoneStarFRC
It's worth very little, if any in the way of HP, but if you want to do it cheaper, go down to the local parts store and buy a #4 size air conditioning hose barbed connector. It's used for splicing A/C hose. That and a couple of clamps and your good to go for about $8 - $10.
HTH
Old Jun 10, 2005 | 10:37 PM
warren s's Avatar
warren s
Its one of those cheap and small mods that in conjunction with other mods may make a small differance.
I did the TB Bypass, the zip tie mod and cut up a traffic cone to make a smooth coupler.
In my mind the car feels faster in the midrange and upper RPM band. And hey, it killed an afternoon doing those mods.
Old Jun 11, 2005 | 02:26 AM
SPD KILZ's Avatar
SPD KILZ
HTH
Its not worth any hp, i bet you would get more out of a tornado...
Old Jun 11, 2005 | 02:44 AM
Shylor's Avatar
Shylor
I think this mod did more for the LT1/LT4's than it does for the LS1/LS6's.
Old Jun 11, 2005 | 11:02 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You can NOT change the air temp by .000001% in the short time the air is in the trottle body ( .01 millisecond). Total waste of time. The throttle body temperature has no effect on the ambient temperature it digest because there just isnt enough time to change it. At ten cubic feet of air a second, that just ain't going to happen. The reason your car runs so good in the winter time is that the throttle body has no effect on the ambient air either. Meaning it does not heat the air up because the throttle body is at 190 F. Mother nature delivers dense 20/30 degree F air in the winter and thats what the throttle body digests.
Old Jun 11, 2005 | 11:11 AM
chrislee2's Avatar
chrislee2
Cruise-In II Veteran
Cruise-In V Veteran
Of course the antifreeze/coolant goes through the TB for the purpose of making sure that 20/30 degree air hasn't created ICE crystals on the throttle blade.
This was the situation that they ran into when they were cold weather testing the C5 up in Canada according to ACAR.
Old Jun 11, 2005 | 11:16 AM
RPOZ16's Avatar
RPOZ16
The TB sticking problem was covered by a GM TSB for trucks. Blade gets covered with emmissions crap which prevents it from moving freely. I had my 2000 Yukon TB replaced under warranty at 36K and I cleaned it myself at 80K to eliminate the sticking. The only problem with the cleaning was the small mess with the coolant. Humm, guess I'll do the $4 bypass to prevent the mess next time. My 2 cents.
Old Jun 11, 2005 | 09:02 PM
LoneStarFRC
Yup. That's the biggest benefit for me. I just run a continuous hose from the radiator over to the fitting on the driver's side, and put some small black caps on the two throttle body hose barbs.
Old Jun 11, 2005 | 09:08 PM
Joe's Eray's Avatar
Joe's Eray
To throttle body bypass
