When changing injector size
Old Jun 10, 2005 | 08:12 AM
truesleeper's Avatar
truesleeper
Default When changing injector size
Do you have to have the computer or mass air recalibrated to make any changes in the injector size? I read it where some are using FORD injectors. What is the best for N/aA 98 ?
Old Jun 10, 2005 | 11:36 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yes, you'll need to adjust the IFR table in your PCM w/ HPTuners (or LS1edit.)
You already have the 28lb injectors; so unless you are making more than, say, 400 RWHP, I wouldn't worry about them.
