Biggest Cam and pass emissions
Old Jun 11, 2005 | 07:01 AM
WKMCD's Avatar
WKMCD
Default Biggest Cam and pass emissions
I'm currently trying to decide what cam to install. What's the biggest cam people are using and still passing emissions? I live in Virginia.
I will be getting a good dyno tune so I'll maximize the probability of passing.
Old Jun 11, 2005 | 07:17 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Look at you getting all crazy talking big cams at 6am.
I made it though on the TR224 with room to spare. I should have went bigger
Old Jun 11, 2005 | 07:32 AM
WKMCD's Avatar
WKMCD
I can't help it. I'm up at 4:15am every day. Something's terribly wrong here.
Old Jun 11, 2005 | 01:54 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
LG makes an emissions passing camm. Add a set of AFR heads and get ~451rwph. For a Z06 anyways...
http://forums.corvetteforum.com/showthread.php?t=984272
Toque
Old Jun 11, 2005 | 10:57 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Another option is the Futral Motorsports F4 cam: 226/226 .575/.574 114 which uses CamMotion lobes. I'm assuming that you have to pass the dyno emissions test where they run your car at 15mph and 25mph, while checking emissions vs. only plugging into the PCM and checking for codes.
Old Jun 11, 2005 | 11:00 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
I passed with 238/244
To Biggest Cam and pass emissions
