Battery Tender & Lightning Strike!
Old Jun 11, 2005 | 06:56 PM
LIGHTNING's Avatar
LIGHTNING
Default Battery Tender & Lightning Strike!
Had a bad storm here earlier today. Battery Tender Plus was plugged in...I have it plugged in to the cigarette lighter in C5. When I got home I noticed electricity must've went out for awhile...but was back on. But Battery Tender lights were dark! Anyone know if a) BT is now garbage & b) could any damage have been done to electrical system/ computers in C5?? I don't see any fuses on BT....& nothing mentioned in instruction booklet.
Old Jun 11, 2005 | 07:40 PM
LIGHTNING's Avatar
LIGHTNING
ok....just checked battery voltage (with engine off)...reads 12v....no codes on DIC...& BT seems to be working again. Can't figure out why charging lights were out & didn't go back on when electric was back....i had to pull plug & re-insert.
Old Jun 13, 2005 | 01:25 PM
C5 Curmudgeon's Avatar
C5 Curmudgeon
I suspect Gremlins...
Old Jun 13, 2005 | 06:20 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Glad nothing was damaged.
Old Jun 13, 2005 | 10:06 PM
MAC5's Avatar
MAC5
I've had this happen after severe lightning storms with surge protectors. I just plugged it back in and the protector operated normally. Your BT must have some similar trip device internally that resets after disconnecting from the outlet.
Old Jun 14, 2005 | 03:53 AM
probaja's Avatar
probaja
Unplug and replug, should be fine -
To Battery Tender & Lightning Strike!
