Keyfob amnesia
Old Jun 12, 2005 | 11:44 AM
speedfreek155's Avatar
speedfreek155
Default Keyfob amnesia
First I'm sorry if this is a dupe , but I searched and couldn't find answer . I replaced the battery in my keyfob , relearned the fob , and it keeps losing the memory after less than an hour . Any help would be appreciated and as always thanks in advance .
Old Jun 12, 2005 | 01:06 PM
JameyTurner's Avatar
JameyTurner
Too Much Fun
My fiance's 99 has the same problem.....I am looking at just buying a new fob, I think this is probably the problem......but I am anxious to hear from anybody else that may have/had this problem and what their solution was....
Old Jun 12, 2005 | 01:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First thing to do is see if you have any DTC codes in the DIC. Here is the procedure.
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/Codes_Page.htm
Once you write all of the codes down, clear them and when the FOB fails again, check the codes again. Post those codes.
A battery low on charge or one that is going bad can cause the BCM to loose the FOB sequence code and it will stop working until you re-sync. Can you do the RE SYNC procedure and get it to work for a chort period of time??
Bill C
Bill
Old Jun 12, 2005 | 02:25 PM
speedfreek155
Bill C
Bill
I can get the fob to work for a short time , then it will stop , I re-learn fob and the cycle continues .
Old Jun 12, 2005 | 10:54 PM
vizette's Avatar
vizette
Well, i've got two answers for this, the first is, when mine started this, i ended up having to buy a new fob.
The second is, someone posted on repairing the fob, so i went back and was able to repair my old one. There is a rectangular component at the top of the PC board that had popped loose from the solder connection. After touching it up, it worked fine again.
-Rich
Old Jun 12, 2005 | 11:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please list all of your codes. That will help us diagnos yor problem.
BC
Old Jun 17, 2005 | 04:24 PM
speedfreek155
Updated !!! I touched up the solder connections on the IC and the crystal and the remote came back to life , so anyone with this problem may want to try this fix , thanx for all of the input and hope this helps some others .
To Keyfob amnesia
