Brake bleeding
Old Jun 14, 2005 | 05:43 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Default Brake bleeding
RR-->LF-->LR-->RF is the order?
Old Jun 14, 2005 | 05:47 PM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
I thought it was right rear, left rear, right front, left front???
Old Jun 14, 2005 | 07:53 PM
Patches's Avatar
Patches
That is the correct bleeding sequence for your '03. I believe the conventional sequence was changed in '01 when they changed the brake line plumbing.
Old Jun 14, 2005 | 08:57 PM
allanlaw's Avatar
allanlaw
Old Jun 14, 2005 | 09:07 PM
Jeff Jeff's Avatar
Jeff Jeff
That is the correct sequence for 2001 and up.
Old Jun 14, 2005 | 09:23 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I agree, but... I'll admit, I usually do it the old fashioned RR, LR, RF, LF and have had no problems. So, if you have done it the "wrong" way, I wouldn't lose any sleep over it.
I also believe the proper way to bleed the brakes is to bleed them with the ignition off, then with the ignition on (but car off). I don't have my shop manual with me so I can't confirm the totally correct method.
But, once again, I tried this a few times and saw no difference so stopped doing it and just do it with the ignition off.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Brake bleeding
