Pegged Oil Pressure
Old Jun 15, 2005 | 01:41 AM
madhouse98's Avatar
madhouse98
Default Pegged Oil Pressure
I have had my 98 for a couple of months. I have put two sending units in it. The first one lasted 10 min. The second on lasted 2 weeks. It is apparent after reading the forums that this is a common problem. My questions is this. Is there some type of fix for this problem? Any help would be appriciated.
Old Jun 15, 2005 | 02:08 AM
vectorz's Avatar
vectorz
Check w/ your Chevy dealer parts dept to ensure you're using the latest part #.
http://forums.corvetteforum.com/show...um_id=1&arch=1
Old Jun 15, 2005 | 09:21 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
The sending units suck. I just replaced mine and it lasted a day, then replaced it again. Still working (fingers crossed)
Steve
Old Jun 15, 2005 | 03:15 PM
C5Burns's Avatar
C5Burns
Oh yeah, this seems to be common, I have looked all over and have decided to leave it for a little while, it's been bad for a month now and I have no immediate plans to fix it.
http://forums.corvetteforum.com/show...ure&forum_id=1
https://www.corvetteforum.com/techti...=246&TopicID=1
There should be more than enough info on these threads for you. 84zz4vette has had a bad sensor for 6 or 7 months now and it's still broken. Not an emergency but you will deffinately save $$ if you do it yourself.
Bob
Old Jun 17, 2005 | 10:28 PM
madhouse98's Avatar
madhouse98
Thanks for the informtion. Has any one heard of some type of electrical feed back or short that would take the sending unit out?
Old Jun 17, 2005 | 10:35 PM
LoneStarFRC's Avatar
LoneStarFRC
www.rockauto.com
Order the PS308, made by Standard Motor Products. Mine was a one time replacement over a year ago and as our Aussie friends say "No worries". BTW, be sure to properly torque the new unit into place. Do not go "Gorilla" on the tightening, and preferably use a six sided deep- well socket of the correct size. Seems like I remember it being a 22mm.
HTH,
Robert
BTW, when you download their online parts catalog, click on Chevrolet, then year, then model and the click on "Electrical-Switch & Relay" folder on the menu. Some of the ongoing issues that some people have been having with the Delco units was one of the main reasons I decided to go with Standard. Standard has been around for a very long time in the parts business.
Old Jun 18, 2005 | 02:42 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Originally Posted by LoneStarFRC
www.rockauto.com
Robert, the description says it comes with gauge.
Does this sender use its own gauge or or does it connect into existing wiring and use the stock dash gauge?
Old Jun 18, 2005 | 04:55 PM
RCK1999's Avatar
RCK1999
Sensor plugs into existing wiring and uses the stock dash gauge.
Old Jun 18, 2005 | 06:26 PM
LoneStarFRC
I saw that wording on their listing too and knew what it meant. Many years ago I used to work in the aftermarket parts business and got very used to many of the more common abbreviations and descriptions that various manufacturers used in their catalogs, etc. The "w/gauge" is referring to the car that you're looking up parts for. In this case "Chevrolet, 19XX (or 20XX) year, and model (in this case "Corvette"). The folks that put catalogs together many times don't know that a particular vehicle (car,truck, etc) only has a gauge like we do. Some listings on some vehicles may include sending units for vehicles with an "idiot light" as well a gauge. Don't forget, RockAuto's catalog covers a whole slew of other vehicle too. HTH
Robert
Old Jun 18, 2005 | 07:44 PM
Joe's Eray's Avatar
Joe's Eray
Mine went out over a year ago. With all the complaints of them not lasting I think im going to leave the old one in.
Old Jun 18, 2005 | 10:23 PM
LoneStarFRC
Bummer. Sorry to hear it. Since I have not experienced this problem after having installed the PS308 from RockAuto, is the main reason I'm sharing this fact with everyone.
BTW, I ran with my old sender leaking for a few months before changing and when I finally did I noticed the oil seepage was trying to run down over onto my bellhousing. Nothing ever got inside and the clutch assembly stayed dry, but I figured it was just a matter of time. It's been my experience that leaks of any sort only stay the same or get worse over time (usually worse). HTH
Robert
Old Jun 19, 2005 | 12:41 PM
craigo's Avatar
craigo
From: "Second place is just the first loser" Edmond, Oklahoma
i own a 98 99 & 2000 C5 - everyone of them pegs the oil pressure gauge and always has...... i finally gave up and just ignore it. I make sure and change and check oil all the time...........
To Pegged Oil Pressure
