***Cooling issues...car running hot**
Old Jun 15, 2005 | 03:07 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default ***Cooling issues...car running hot**
Ok, heres the deal. The car seems to get rather hot (220-240) when parked and idling with the A/C running or if I am sitting in traffic at a light for any length of time. I have noticed that if when the car gets up there in temp if I kill the A/C it will begin to cool down on its own if I am parked. Also no issues when I am moving due to increased air flow.
I have done all the obvious stuff ...coolant level, debris etc.
I have a 172 stat in there and when my car was tuned we made the necessary adjustments for the fans. So my question is this, do I need to possibly change the fan times to allow them to come on sooner and run longer or do you think maybe my T-stat is just F'd up and I need a new one.
Or is it just because its so frickin hot out it doesn't matter
Old Jun 15, 2005 | 03:15 PM
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I think she is pissed at you after finding out about you new love that 505 HP ****
Old Jun 15, 2005 | 04:12 PM
pewter99's Avatar
pewter99
nah she said she is good with threesomes
Old Jun 15, 2005 | 05:58 PM
vetteamerica's Avatar
vetteamerica
What about a 160 stat??
May be worth trying
good luck....
Old Jun 15, 2005 | 07:09 PM
Bill Dearborn's Avatar
Bill Dearborn
May be worth trying
good luck....
Assuming he has a properly operating thermostat what good would it be to change to a lower temp thermostat? The one he has is already wide open. He could have a 195 in there and it would be the same.
Although the temps sound about right for a stock car if your fan was programmed to come on earlier it seems the temps would be lower. You should probably see what temp the fans kick on and off. You may have lost your fan programming.
Bill
Old Jun 15, 2005 | 07:57 PM
Vector's Avatar
Vector
[QUOTE=pewter99]Ok, heres the deal. The car seems to get rather hot (220-240) when parked and idling /QUOTE]
Actually for a stock set up that sounds pretty normal - GM keeps temps up for cleaner emmisions. Reprograming fans - turn on temp - will remedy that. Yes, you need an external 'box' to program fan temps. My tuner did mine. I'm sure others can chime in to help you out.
Old Jun 15, 2005 | 09:33 PM
pewter99's Avatar
pewter99
[QUOTE=Vector]
well like I said it is NOT stock....I have a 172 stat in there...car never saw those temps before so I may tweak the fans some
Old Jun 15, 2005 | 10:58 PM
fdxpilot's Avatar
fdxpilot
Check under the car to see if you sucked up some junk that is blocking the AC Evaporator/ Radiator.
Old Jun 15, 2005 | 11:16 PM
ECV-Tony's Avatar
ECV-Tony
If temps are suddenly running higher then this may very well be your prob, if everything (fluid levels, t-stat, no crack in the block) else has checked ok.
Old Jun 15, 2005 | 11:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
search for my posts in other overheating threads for pics of what my radiator looked like after I got it out..my temps were exactly the same as yours with a 170* stat, they're now down to 190ish sitting in traffic with 104+ reading on the climate control and AC on high all day long...
Old Jun 16, 2005 | 12:24 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Old Jun 16, 2005 | 09:51 AM
pewter99's Avatar
pewter99
yeah I know there is no crap up there but I may need to do a very thorough cleaning of the fins
Old Jun 16, 2005 | 09:53 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
is your radiator cap in good shape? if it leaks, temps will climb as a result.
VR
Old Jun 16, 2005 | 11:00 AM
pewter99's Avatar
pewter99
yeah cap is good....I am thinking I may just have lots of crap in the fins that is gonna require some work...
sounds like a good excuse to drink beer
Old Jun 16, 2005 | 07:50 PM
vetterdstr's Avatar
vetterdstr
VR
Old Jun 17, 2005 | 10:59 AM
pewter99's Avatar
pewter99
well I got in there and seperated the 2 pieces and really cleaned it out....still flushed out a buncha crap....its a PITA for sure...I need to find a different type of nozzle to really get down in there but it seemed to do pretty good....anyhow we will see how it goes
Old Jun 17, 2005 | 11:03 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Cool, I finally just took the radiator and condensor out after trying to do it with it in the car, hopefully you got yours fixed though!
Old Jun 17, 2005 | 11:08 AM
pewter99's Avatar
pewter99
yeah I was going to pull them all the way out but when I saw I could seperate them a bit without alot of effort I figured I would try the easy way first....
To ***Cooling issues...car running hot**
