BIG Problem Lowering Front off Car Please HELP!!
Old Jun 15, 2005 | 05:21 PM
1-BAD-C5's Avatar
1-BAD-C5
Default BIG Problem Lowering Front off Car Please HELP!!
Okay i started lowering the front of the car, i followed all the procedures to extract the adjustable bolts and cut the bushings, however when i got to taking the front two adjustable bolts out of the leaf spring(reverse thread so i turned them clockwise to take them out) both heads of the bolts rounded off. I dont know what to do i know chevy doesnt sell these bolts and i want to lower the front of the car has anyone ever run into this problem. If so what did you do to fix it and get your car lowered... Please someone help i need advice.
Old Jun 15, 2005 | 05:42 PM
vetteamerica's Avatar
vetteamerica
Same thing happened to my friends 2000, he used vise grips to turn the bolts. Doesn't look pretty when done but does work.
Good luck
Old Jun 15, 2005 | 05:49 PM
georges03zo6's Avatar
georges03zo6
Call MSI Motorsports (forum vendor) and they will sell you some front bolts.
George
Old Jun 15, 2005 | 10:45 PM
corvette dave's Avatar
corvette dave
You can just reuse the bolts. They should turn by hand. If not, then turn them by gripping the metal part of the bushing with vice grips and adjust there.
Hardbar makes the replacement bushings.
BTW: The bolts are not reverse threaded. Clockwise is normal.
Good luck with it.
Dave
Old Jun 16, 2005 | 01:50 AM
1-BAD-C5's Avatar
1-BAD-C5
i tried vice grips with it and still nothing, these bolts are not bugging for nothing,... all i want is to get them out does anyone have MSI's number for me so i can give them a call so i can replace the two front bolts... Any other helpful hints would be appreciated, thanks
Old Jun 16, 2005 | 08:26 AM
VetteTech81's Avatar
VetteTech81
Yep it's a PITA sometimes when the bolts are seizes, you can soak them in oil, thats about it because obviously you can't heat them. Last resort to save the spring is to remove the spring and try drilling out the stud, and extracting the remains, then run a tap through it to clean the threads. Corvettes do corrode and rust.
-=Rick
Old Jun 16, 2005 | 11:15 AM
C5 ChemE's Avatar
C5 ChemE
I've been having the same problem with my front bolts... won't turn for $hit...
I love the guys who say "oh yeah, they'll just turn by hand..." no- they really won't. even soaking them in oil hasn't done anything
I also don't know how people are getting vice grips down onto the "metal part of the bushing"... can't seem to squeeze mine in there
Still waiting for some good advice...
Old Jun 16, 2005 | 12:32 PM
corvette dave
Chem,
You need to separate the lower control arm to get access to the bottom of the bushing.
The originator of this thread said he turned the bolts clockwise to take them out. I thought he already had them out. Sorry. That is why I said the bolts should turn by hand, meaning when he put them back in.
I can tell you all of them do not turn by hand. You already know that!
Lots of oil, separating that lower control arm and vice grips on the bushing should work for both of you. If not, the spring will have to be removed and the bolts drilled out. Or replace the spring.
Dave
Old Jun 16, 2005 | 12:42 PM
1-BAD-C5's Avatar
1-BAD-C5
Originally Posted by corvette dave
Chem,
The orininator of this thread said he turned the bolts clockwise to take them out. I thought he already had them out. That is why I said the bolts should turn by hand, meaning when he put them back in.
Dave
Ill try it out tomorrow and hope for the best,.. ill let you know what happens, also does anyone have MSI's number so i can get some new front adjustable bolts? Thanks
Old Jun 16, 2005 | 01:54 PM
2KVetteMan's Avatar
2KVetteMan
Make sure the rubber bushing is not catching on the spring. Spray some WD40 on the bottom of the spring to get you some lubrication and why not do the entire bolt.
This happened to me, and I used a vice grip.
Old Jun 16, 2005 | 02:02 PM
Raced Guy's Avatar
Raced Guy
I welded another nut to the top of it and it came loose, otherwise i dont think it would have came, tried vise grips and about every typed of lube.
Old Jun 16, 2005 | 02:48 PM
sprinter's Avatar
sprinter
WD40 and leave overnight. Cant remember how long the thread sticks out but can you get two nuts on? Otherwise weld a big nut in place.
Old Jun 16, 2005 | 02:59 PM
corvette dave
These last few posts are very good.
If you can get two nuts on the threads and tighten them together you might be able to turn the bolt using the top nut.
Some hardware stores and nut and bolt suppliers sell thin nuts which might allow you to get 2 on.
The idea of welding a nut to the bolt is also very good.
Dave
Old Jun 16, 2005 | 11:23 PM
1-BAD-C5's Avatar
1-BAD-C5
Everyone here has given me so many good ideas i cant wait to try them all out. Thanks for your help, hopefully these two bolts will bust loose .
Old Jun 16, 2005 | 11:26 PM
1-BAD-C5's Avatar
1-BAD-C5
Dave
you mean screw two nuts onto the top of the leaf spring(adjustable bolt) correct? And then just torque down on them?
Old Jun 18, 2005 | 10:19 AM
ghoffman's Avatar
ghoffman
Cruise-In II Veteran
Well, you now know why we make our front spring kit using stainless steel for the threads. The rust literally welds the threads together on the stockers and Chevy does not sell replacements, so we do.
http://www.hardbar.net/page_corvettesuspension.htm
Gary Hoffman
Hardbar.net
Old Jun 18, 2005 | 11:42 AM
corvette dave
Yes, tighten the nuts against/to each other. Then turn only the top nut clockwise.
Dave
To BIG Problem Lowering Front off Car Please HELP!!
