tire sensor battery replacement
Old Jun 15, 2005 | 09:48 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default tire sensor battery replacement
my 98's tp sensors batt. are dead, i used a knife starting on the rt side of the sensor and scraped away the grey material, now i'm looking at a $5 watch battery w/ a small lead glued to it, anyone successfully replace the battery? i'm aware of nericreations and the exchange program, if you're running a cam w/<.600 lift don't reply
Old Jun 15, 2005 | 09:55 PM
RCK1999's Avatar
RCK1999
OK then, I won't reply.
Old Jun 15, 2005 | 10:02 PM
SteveDoten's Avatar
SteveDoten
it's sarcasm, if you've got knowledge, post it
Old Jun 15, 2005 | 10:15 PM
RCK1999's Avatar
RCK1999
Is that a challenge or a demand??? Boy, not very diplomatic - must be a democrat -
I'll be nice! Here is a link to a thread that contains all (and more) of the information for which you seek: http://forums.corvetteforum.com/show...1030589&highli
Old Jun 15, 2005 | 10:49 PM
LoneStarFRC's Avatar
LoneStarFRC
The leads going to the batteries are either spot welded (battery end) or soldered (circuit board end). Not glued. Unless you just want to go through the process, Nericreations does them fairly cheaply and offers 48hr turnaround time. HTH
Old Jun 15, 2005 | 11:10 PM
SteveDoten's Avatar
SteveDoten
Default not left wing
thanks for the link, i'm rep., spent some time in san antonio and wichita falls in air force crew chief school, so i was a texan for a awhile too
Old Jun 16, 2005 | 10:29 AM
ericdwong's Avatar
ericdwong
I've replaced all 4. I posted in the link above. I used a dremel with wire brush to dig into the parts. Much faster and cleaner ! Be sure to wear respirator if you do it this way.
To tire sensor battery replacement
