Replacing header gaskets...easy way??
Old Jun 16, 2005 | 05:18 PM
SPDKLZ's Avatar
SPDKLZ
2016 C5 of Year Finalist
Default Replacing header gaskets...easy way??
I currently have Breathless Step II Headers and have hissing coming from the drivers side. I tightened the bolts I could reach, but that did not work.
I just ordered a set of Percy dead soft gaskets and Breslin split-lock header bolts to help solve my problem.
When I tried tightening the bolts, there were a couple I could not reach (far back on driver and pass sides). Does anyone know of special tools or tricks I can use to get these out? I am definately not looking forward to doing this, but it needs to be done...hopefully for the last time!
Rodrigo
Old Jun 16, 2005 | 07:09 PM
vettenuts's Avatar
vettenuts
I used a small Craftsman 1/4 socket set to get mine in prior to using the torque wrench.
In your situation, I think I would remove the hard ones first while the others are still tight so there is less chance of cross threading, then remove the inners and notch the two end holes in the gasket so you can drop it in place then put in the middle bolts and finally change out the fronts.
Old Jun 16, 2005 | 08:17 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Your gonna love getting to the back bolt on the drivers side with the Breslin bolts
Get a 1/8 inch allenwrench/socket and a 1/4" drive wratchet to tighten the locks.
Old Jun 16, 2005 | 10:12 PM
wrustywrench's Avatar
wrustywrench
I found a 10 mm reversable ratchet box end wrench worked very good on installing my LG headers with stock bolts......
To Replacing header gaskets...easy way??
