I bought all 4 Gm performance rotors, and I have never swapped rotors before. A friend told me that the rotors should simply slide off the studs after I remove the calipers. Is it really that easy?
Yes, I put something under the caliper to hold it up as to not put pressure on the hose when you take it off the disk, usually use a bucket upside down. I have never changed these out, but you will more than likely have to expand the caliper. I open the bled and put pressure expanding the caliper.There could be other tricks. Careful with the DOT 3 brake fluid. And try and not get air into the system. If you do you will have to bled that brake of the air.
You'll need to remove the caliper brackets as well which are somewhat of a PITA. Each has 2 bolts that are on TIGHT. When you reinstall the bracket, make sure you clean up the bolts well, put some red high-strenght loctite on them and torque to 125 ft/lbs.
Also, clean up the hub surface with a wire brush before putting the new rotors on. A little bit of rust can cause vibration.
