Replaced stock rotors with sportbrakes D&S Rotors. Calipers will not fit back over the pads I just pulled off. The original rotors were recently turned and new pads installed. Do I need different pads, need to release the brake fluid pressure and bleed the system, or what?
Thanks...
You need a caliper press to press the pistons in slightly so it will fit back on the rotor. I think you can get them at Sears or if you have a C-clamp, it will work.
