Code is for "three way catalyst (TWC) low efficiency bank2"
From the service manual: "Conditions for setting the DTC: The PCM determines if the oxygen storage capacity of the catalytic converter has degraded below a calibrated threshold."
I've had the Dynatech headers and high-flow cats on for over a year, and never had any codes until last week when this P0430 code was set.
Anyone else have this with long tube headers and high-flow cats?
You need to get the car edited have code deleted. Common problem with header install.
Try just resetting the dic and see how fast it comes up. You might have a bad o2 sensor.
I put the Dynatech Supermaxx system with high flow cats, x-pipe and Corsa Indy's in early May. Mine has thrown several (7 or 8) 0420 and 0430. Has to do with the high flow cats heating and effeciency. No problem, just reset. Can be edited out if it bothers you. All this is based on you not having tp pass emissions testing. That could be a different thing. My 2c.
You could also unplug your rear 02 sensors and install a set of 02 sims. Cheaper than programming them out...but if you were planning on future tuning anyways, have them edited out then, it's the more elegant solution.
