LS7 Crate Longblock Pricing
Old Jun 22, 2005 | 06:17 AM
  #41
SpinMonster's Avatar
SpinMonster
Originally Posted by Face
Better parts, and it's only a cam swap away from making more power than a 402 for less $.
Those pistons are better than a forged 402???
You can get a 441 600rwhp for 14k. Actually I don't see what all the stink is about. Just about every tuner offers a darton re-sleeve 427+ that has been perfected and will outperform this motor in every way. The rotating assembly is garbage and it is simply a great STOCK offering. The aftermarket has had much better for a long time now. If you buy this motor the pistons and connecting rods are the first to go. You can buy the heads and intake for any block if they prove themselves to be better than a ported and worked LS6 or AFR with the LSX manifold.
Buy the block and get a great rotating assembly. If you cant do the work buy a forged superstroker from an established tuner that runs 9's in their R&D cars. It will save lots of $$$
Old Jun 22, 2005 | 01:06 PM
  #42
TXNC5's Avatar
TXNC5
That may all be a little overstated? Perfected? How many 441 600rwhp cars are running around? How many without any problems?
It is a great Stock offering, but I wouldn't say it is "garbage".
FYI, LS7 Head Flow
I agree with some of your points, but from a reliability, warranty, etc standpoint, the LS7 motor with bolton's will be f'ing bad to the bone.
If you haven't read this about C5R blocks vs Re-sleeved blocks (I know we are not talking about a C5R block), you might find it interesting. GM does some things right. Besides, the guy that wrote that knows his $hit.
Old Jun 22, 2005 | 01:35 PM
  #43
SpinMonster
So does CARTEK and EAST COAST SUPERCHARGING unless 700 flywheel power and the ability to go to much higher on boost is a bunch of lies. As far as how many of these are driving around...a few more than LS7's
NO I think its accurate. The machine shop in NJ where CARTEK gets their blocks done has had 1 (THATS ONE) failure in 5 years. Besides which you can just buy the LS7 block now if its so great.
Yes the rotatng assembly is garbage.
FYI, LS7 Head Flow
then buy the heads and manifold but TEA has gotten near 340 cfm out of the LS6 and AFR heads...
If you get it installed at the tuner in question it comes with a warranty all for 14k
The issue you are overlooking is that you are buying a crate motor that has crap pistons that would have to be changed for any meaningful power increaseunless your goal is 500-550 rwhp in which you can get that with a 8k 402. Yes there are lots of them out and you can go get lots of quotes to show us all from LS1-tech. Yes the LS7 is good but to get to the level of a forged 427 that is already out and has been for years it needs a few thousand in mods....why when you can just get one installed for the same price as this stock crate motor?....witrh a warrany.
Old Jun 22, 2005 | 01:36 PM
  #44
J-Rod's Avatar
J-Rod
GM stated the pistons were forged. Are folks now saying the aren't?
Put a camshaft in the motor, and a set of headers and prepare for some crazy, crazy power...
If you look at what a 427 costs from many of the "tuners" out there. This price is a bargain.
Old Jun 22, 2005 | 02:21 PM
  #45
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
J-rod,
I think you are on to something. Cam and maybe springs and you got a big power machine.
Now back to the cast pistons. N/A motors built by GM run 220-230 water temps, 300 oil, small rings, head cambers that don't match bores(C6). This has Detonation all over it. Cast pistons are not good things.
Randy
Old Jun 22, 2005 | 02:26 PM
  #46
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
The availability of the LS7 cylinder head castings, intake manifold and the 4.125" bore block excite me but the whole crate motor idea does not.
The $13K price is not a bad deal at all if the 500hp will keep you happy and you dont mind the work required for a retrofit.
The titanium parts in the motor have a nice WOW factor, but I have a feeling they are not race quality titanium parts like are available for 9000rpm race engines. I have a feeling these are more of a titanium alloy that help a bit with weight and a lot with marketting.
Either way, kudos to GM for coming out with a kickarsed OEM engine that is available in a crate!
Old Jun 22, 2005 | 02:33 PM
  #47
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The race prep of the C5R block is where I'd like to go - with the LS7 heads, intake, crank and hopefully the Dry Sump. Will the Dry Sump work with the C5R block???
Old Jun 22, 2005 | 02:53 PM
  #48
J-Rod's Avatar
J-Rod
The rods are TI. The specific alloy being used has been posted. For some reason I am think it was 6ALV something... Anyway, it was good alloy from what I remember.
The only work I see is knock sensors and the dry sump.
Old Jun 22, 2005 | 05:50 PM
  #49
John Nowak PE's Avatar
John Nowak PE
According to the catalog, the C5R block is machined for a dry sump system. I don't know if the system is the same one as what is in the new Z....
Old Jun 22, 2005 | 06:22 PM
  #50
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
We have put many dry sump (aftermarket) systems on ls1, ls6 and the c5r block. They have worked great, but this new system from GM has us thinking. We are looking foward to the first one we have pulled apart. Then we will know much more on the whole motor-oil system.
Randy
Old Jun 22, 2005 | 06:36 PM
  #51
boblackhardtop's Avatar
boblackhardtop
One thing I've learned about estimate is that I usually have to double it by the time everything is done.
Peoples have been guesstimating the cost of getting this crate motor to work in the C-five at about $3000 which mean it will likely be closer to $6000.
A good deal still but not a great one.
Old Jun 22, 2005 | 06:40 PM
  #52
boatboatboat's Avatar
boatboatboat
I would think that someone could take a ls2 and get as much HP out of it as a LS7 for less money.
