Oil cooler on a C5
Old Jun 22, 2005 | 11:59 AM
zeusoftexas's Avatar
zeusoftexas
Default Oil cooler on a C5
Has any one used a oil cooler off a 6.0L GM truck motor on the LS1 motor? The block that the temp sensor plugs into looks like a blank of the oil cooler block on my friends truck. I also looks close the block found in the 21st CM oil cooler package.
Any thoughts?
Old Jun 22, 2005 | 12:16 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Any thoughts?
I'm sure the stocker will work, but you'll have to make some fitting conversions and such to get it to work.
You can make your own kit using the Xtreme LS1 adapter for about $400 (which I'm about to do)
Compliments of Vettedrmr.
http://webpages.charter.net/VetteDrm...stallation.doc
Additionally, the 21st MC kit does not have a thermostat which is a MUST if you plan on driving the car in cool weather.
Old Jun 22, 2005 | 12:41 PM
zeusoftexas
Thank you for the information.
I was going to place mine behind the license plate. Cut a hole behind the plate and when I’m driving around town the plate will cover it (no air flow) when I go to the track take the plate off and have air flow. I don’t think I will need a thermostat that way.
Old Jun 22, 2005 | 02:48 PM
AU N EGL's Avatar
AU N EGL
DRM ( Doug Rippie Motorsports ) Forum fender has an oil cooler / radiator combo. Many ppl have purchased this and Install.
I use the GM T1 oil cooler set up.
Trans cooler, radiator, oil cooler
Old Jun 22, 2005 | 03:04 PM
Umrswimr's Avatar
Umrswimr
St. Jude Donor '05
How are those coolers attached at the top? The only thing I don't like about drmr's setup si thatthe top of the cooler is leaning agaianst the radiator. It's probably OK, but I don't want to risk it if there's a more secure solution.
Old Jun 22, 2005 | 03:16 PM
Special K's Avatar
Special K
How are you going to cut an opening behind the plate? That's where the bumper is. Just curious.
Old Jun 22, 2005 | 03:27 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
There's enough room up there to mount an oil cooler, even though it will be a tight fit with the bumper.
Old Jun 22, 2005 | 05:46 PM
AU N EGL's Avatar
AU N EGL
We fabricated a bracket. Just a strip of steel runing side to side.
Old Jun 22, 2005 | 09:06 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I've seen the DRM kit and it is very nice and very similar to the GM T1 cooler I now have.
Having done this once by myself, where I researched and bought all the parts, adapters, fittings, etc, I recommend buying a kit. The extra $$ will be well worth the aggravation you save.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Oil cooler on a C5
