Advice on Pulling Spark Plugs
Old Jun 22, 2005 | 05:53 PM
jag71usa's Avatar
jag71usa
Default Advice on Pulling Spark Plugs
Is changing plugs on a c5 harder than on a Camaro? Is there room enough to work in there and pull them? Any advice offered is appreciated. Am getting y C5 this week.
Old Jun 22, 2005 | 06:26 PM
MagRed_00's Avatar
MagRed_00
The C5 is way easier than the camaro. The engine doesn't sit nearly as far back as the F-body. The only problem is the driver side rear plug. I used a U-joint right on the socket and about 10" worth of extensions. The rest are pretty easy. It took me about 1 hr. the first time I did it. Good Luck!!
Old Jun 22, 2005 | 06:37 PM
Scubanme's Avatar
Scubanme
Old Jun 22, 2005 | 06:44 PM
jimcork1's Avatar
jimcork1
I used a ball socket swivel vs the universal swival on a the plug socket. The universal if very limited and you could break the plug off due to the angle. The ball socket does not have this problem. I bought one from snapon and was robbed at about $55 for the socket and $25 for the shipping for just 1 socket. I later found harbour freight had a entire set for about $55. So you might shop around. Changing all but the ds. rear is pretty easy as plugs go.. 99Nassau blue
Old Jun 22, 2005 | 06:49 PM
csexton's Avatar
csexton
Snap on makes a great double swival socket that is great for plug swaps.
Old Jun 23, 2005 | 05:14 AM
blktie8's Avatar
blktie8
SNAP ON
Double Swivel spark plug socket I paid 40.00
Ngk plugs and new wires
tr55 and magnecor
www.magnecor.com (KV85)
To Advice on Pulling Spark Plugs
