Shift Question
Old Jun 22, 2005 | 06:55 PM
glind46677's Avatar
glind46677
Default Shift Question
I have a 2004 Automatic with 273 rear gears. When I start off in 3rd how high can I run the rpm's to before shifting into overdrive????
Old Jun 23, 2005 | 01:07 PM
Boob's Avatar
Boob
It's all in the tuning and programming.
Most 4L60E's have an issue of not shifting from 3rd to 4th at WOT. This is one of those monsters that has been plaguing F-bod guys forever.
The solution is to first adjust shift points based on rpm. This will not fix the problem however.
Then in the tables you move to actual mph shift points. To fix the problem you have to adjust the mph shift points down until the problem goes away. The only way to do it is to find a flat open area and do WOT runs and adjust accordingly until it shifts well at WOT.
Don't know if that's what your question was leading to, but that's the solution anyway.
Old Jun 23, 2005 | 02:20 PM
cenzo's Avatar
cenzo
5800 will allow for some delay before hitting the rev-limiter. You can sneak up on it a little at a time from there. I think 6200 whacks the limiter.
cenzo's Avatar
cenzo
5800 will allow for some delay before hitting the rev-limiter. You can sneak up on it a little at a time from there. I think 6200 kisses the limiter.
To Shift Question
