What causes carbon build up?
Old Jun 24, 2005 | 12:57 AM
Joe's Eray's Avatar
Joe's Eray
Default What causes carbon build up?
After having my upper intake cleaned and my injectors my car is a beast. How can I prevent carbon from building back up? What causes it?
Old Jun 24, 2005 | 01:27 AM
Dirty Howie's Avatar
Dirty Howie
How did you do the upper intake....the dealer?
I just recently did H/C so I actually saw the buildup on valves and pistion heads. My car also pinged...probably due to this. I have no pinging now with my new H/C.
I'm no expert so I will probably be corrected but it is my understanding that carbon build up is from oil in the fuel mixture which is not fully burned and sticks to combustion surfaces. It is prevented by not allowing oil into the system (catch cans), burning hotter, and additives such as Techroline(sp) and Torco.
DH
Old Jun 24, 2005 | 02:13 AM
Joe's Eray's Avatar
Joe's Eray
Had a tuner do it. Dont know exactly how he did it though.
Old Jun 24, 2005 | 07:05 AM
WKMCD's Avatar
WKMCD
I run BG44k every 3k or so. I've never had a carbon or injector problem in any of my cars. Looking through the spark plub hole it's nice and clean.
Also, I tend to drive the living pi$$ out of the vette.
Old Jun 24, 2005 | 07:20 AM
AU N EGL's Avatar
AU N EGL
Isn't most carbon build up a result of incomplet combusiton? Sounds like the RX is more time at WOT
Old Jun 24, 2005 | 10:47 AM
lotzahp's Avatar
lotzahp
I remember when little old granny's Lincoln wouldn't run so good after a year of puttin' around town. The fix was to run it WOT several time and "blow the carb's out", today known as carbon deposits.
Old Jun 24, 2005 | 02:31 PM
yellow01's Avatar
yellow01
Common when too high an octane is run (vs. what is needed)
Assuming you're only burning a bit of oil (i.e. through PCV or something) some time at WOT could be just what the doctor ordered.
BUT, I spent my life at WOT in my 2k1 before I grew up (mentally) and it pinged like mad; however, it had the ring issue and burned a BUNCH of oil, so different story.
If the buildup isn't too bad, a bottle of techron and some WOT will probably do wonders.
To What causes carbon build up?
