cam position sensor code! help
Old Jun 24, 2005 | 11:06 PM
whitecorvette72's Avatar
whitecorvette72
Default cam position sensor code! help
my car set the code dtc po343. we have changed the sensor and still
setting code. has anyone experienced this? if so what cured it?
Old Jun 25, 2005 | 08:00 AM
Av8ter's Avatar
Av8ter
I had that problem. I ran continuity checks on the wiring and checked the sensor and it all checked good. I went ahead and changed the sensor for the hell of it and that didn't fix it. I then had the ECM computer replaced under warranty and then had to get it reprogrammed for my supercharger, but that didn't fix the problem either. The only other alternative was to check the cam. So I pulled the radiator, steering rack, etc. and when I got to the timing cover off I could see what the problem was. All 3 bolts that attach the cam gear to the cam had come loose and backed all the way out to where the bolt heads were rubbing on the timing cover and even the alignment pin that aligns the cam gear to the cam was gone, which I later found when changing the oil because it was stuck to my magnetic oil drain plug. Anyway, this caused the cam to move aft which prevented the reluctor wheel on the back end of the cam from lining up with the cam sensor. This was when my engine was completely stock internally. So the f**king idiot moron who assembled the engine from the factory didn't tighten all the bolts nor did he use loctiite. Anyway, I got new bolts, gaskets, cam, timing cover, and cam gear from the dealership for free because my car was all under warranty. Anyway, since I had it all tore apart, I installed an aftermarket cam, double roller timing chain and put it all back together and never had another problem out of it.
And to make a long story short, they didn't want to work on my car under warranty because they said the supercharger caused internal damage. I knew that was BS because the supercharger has no effect on the cam whatsoever and this engine only had 1000 miles on it. Once I had the engine apart and showed the worn bolts, cam gear, and timing cover to the manager at the dealership, he agreed with me that it wasn't my nor the superchargers fault and gave me all new parts for free.
The cam position sensor is only used for starting purposes. Once the engine is started, the reluctor wheel on the crankshaft provides position timing for the computer. The reluctor wheel on the cam has 2 notches that are 180 degress opposite of each other. The cam position sensor has a magnetic pickup that reads these notches. If the cam position sensor is unable to "see" these notches, then you will experience longer than normal engine cranking because the computer is trying to determine when to start the firing sequence and get a code and so on.
What you need to do is a continuity check on the wiring from the cam position sensor plug down to the ECM on the frame at the passengers front fender well. If that checks good, then the only thing left is the cam. Let me know what happens
