Question/harmonic balancer
Old Jun 25, 2005 | 01:23 PM
BoOST88's Avatar
BoOST88
1st Gear
Default Question/harmonic balancer
at idle the pulley seems to have a harsh vibration to it. When reving the motor the vibration smooths out and the pulley spins ture at around 1 and through the rpm. The pully has no dirt or gunk on it giving a false impression that it is vibrating. Is this normal on ls1 motor or is it a sign of a bent flywheel, crank, harmonic balancer, ect.
Thanks Ron
Old Jun 25, 2005 | 02:02 PM
Av8ter's Avatar
Av8ter
Thanks Ron
The harmonic balancer is a 2 piece assembly. You have the inner hub thats bolted to the crank and then you have the outer hub that has the grooves for the belt. Its pressed together with a thin rubber flat ring between it. What youre seeing is normal and is just how the balancer assembly was pressed together. Most have a slight imbalance/wobble look to it.
Old Jun 28, 2005 | 11:04 AM
gfunk's Avatar
gfunk
I also noticed my balancer had a slight wobble at idle, after checking around, I found out these are notorious for eventually comming apart and doing damage, due to a faulty factory design (press fit?)
anyway I had it replaced and it now turns true.
To Question/harmonic balancer
