Flasher???
Old Jun 25, 2005 | 03:36 PM
97Brian's Avatar
97Brian
Default Flasher???
How do i find and replace the turn signal flasher on a C5???
Old Jun 25, 2005 | 03:49 PM
01vetteC5's Avatar
01vetteC5
well i always get my friend to doo it for me since he has a small hand- pop up your lights try and get your hand in there find the light pull it out put in the new one and put it back into the socket
Old Jun 25, 2005 | 03:50 PM
not08crmanymore's Avatar
not08crmanymore
Default turn sig.
if the signals aren't working,it may not be them that's broke!
Old Jun 25, 2005 | 04:14 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
i took the cover off from underneath and reached in there to grab it...its not easy to reach, that's for sure
Old Jun 25, 2005 | 05:09 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The turn signal flasher is actually part of the hazard switch on the dash
Old Jun 25, 2005 | 05:17 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I think it's a fairly tough replacement.
Old Sep 25, 2005 | 10:53 AM
vietvett's Avatar
vietvett
5th Gear
Take the shroud off of the headlight (4screws) reach down and remove the bulb holder replace the bulb and reinsert the holder and reinstall the shroud.
Old Sep 26, 2005 | 10:59 PM
striper's Avatar
striper
I believe it's the flasher itself you want to replace? I've never changed one but it's behind the dash on the right side and not an easy job to get to.
Old Sep 26, 2005 | 11:15 PM
Admiral Fairway's Avatar
Admiral Fairway
According to the manual you have to remove the radio and other parts. But if you search on the forum someone posted a way to remove it without doing this.
To Flasher???
