What is the normal voltage please?
Old Sep 26, 2005 | 11:28 AM
tripod5's Avatar
tripod5
Default What is the normal voltage please?
What is the normal voltage, you should get when you start your car and drive for a bit, without any accessories on. I'm fluctuating between 13-13.8 volts. Is this good or bad?
Old Sep 26, 2005 | 12:27 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Just like mine. It's fine.
Old Sep 26, 2005 | 12:58 PM
Face's Avatar
Face
I wouldn't go by the DIC. Mine at the DIC reads in the 11's, but at the battery and alt it's higher.
Old Sep 26, 2005 | 03:53 PM
Avanti's Avatar
Avanti
Yeah, about the same, with a 6 month old Red Top.
Old Sep 26, 2005 | 04:39 PM
ronwc's Avatar
ronwc
If you are getting a rapid fluctuation in your voltage readout, you may want to check your battery connection. Mine used to fluctuate between 13.2 -14 volts, my headlights would not always pop up first time and sometimes slow starting. Cleaned/tighten my battery connections and solved all problems at once. My voltage now is a steady 13.8-14 volts -
Old Sep 26, 2005 | 06:20 PM
Harlock's Avatar
Harlock
Default What battery?
Hi Folks.
Since we are talking "electrical" I will slip in a question:
Need to change the battery of my beloved 2003 Z06. Any suggestions?
Thanks all
Old Sep 26, 2005 | 07:37 PM
servohead's Avatar
servohead
HMMPH,
I wonder if my car is overcharging.... New AC delco battery in there and I'm ususally seeing 14-14.5 v.....
Old Sep 26, 2005 | 08:13 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Originally Posted by Harlock
Hi Folks.
Thanks all
One of the most popular batteries here is the Optima Red Top battery. It is an AGM battery so it won't leak acid down your wiring harness located directly beneath your battery.
Back to the original question, when the engine is running, my DIC shows around 13-14 volts. That is perfectly normal. It will show less than that when you are in accessory mode.
Old Sep 26, 2005 | 10:58 PM
coolryde's Avatar
coolryde
5th Gear
Originally Posted by servohead
HMMPH,
My 99 Convertible is showing a steady 14 - 14.5 v.
Old Sep 26, 2005 | 11:13 PM
BLUE BETTY's Avatar
BLUE BETTY
my 99 also ahows 14-14.5
Old Sep 26, 2005 | 11:24 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
HMMPH,
No its not.. The average alt charges right around 14.7 volts.
*EDIT* Maybe its 14.4 volts..
To What is the normal voltage please?
