Check Engine Light????
Old Jun 27, 2005 | 11:20 AM
Fast-C5's Avatar
Fast-C5
Default Check Engine Light????
Hello All,
Yesterday I went to my sisters house because my newphew was dying to take a ride in my (new to me) 2000 Coupe MN6. Of course I wanted to show him a good time so I drove the car pretty hard, when I dropped him off the car was doing fine, so I turned it off to let it cool down, went inside for about 20 minutes, and when I got back in it to go home the "Check Engine" light Came on, and Stayed on!!! The car was still running like a top, so previous experience with these lights told me to go home and disconnect the battery for a few minutes and it should go off. Well I left it off for about 15 minutes and plugged it back up and the light is still on!!! What do ya'll think this could be? Also the DIC displayed while driving "Active Handling Warming Up" what does that one mean as well?
Thanks Guys! I hope ya'll can help a noobie out in distress!!!
Sean
PS. I don't usually drive my car that hard, I was just trying to be "The Cool Uncle"
Old Jun 27, 2005 | 12:09 PM
Fast-C5's Avatar
Fast-C5
Is there a way to check codes to see why the light is on?
Old Jun 27, 2005 | 01:07 PM
DaveC4's Avatar
DaveC4
8th Gear
http://forums.corvetteforum.com/show...ght&forum_id=1
Read the instruction on how to pull the code from your DIC. Then go to the link and figure out what it means. The Active Handling warming up is normal. It has something to do with making turns in the car shortly after start up.
Old Jun 27, 2005 | 01:49 PM
Fast-C5's Avatar
Fast-C5
Question answered, it was my Air Temp Sensor, all codes cleared!!! Thanks David! That is very cool that I can do that! This car keeps getting better and better!
Old Jun 29, 2005 | 12:16 PM
Fast-C5's Avatar
Fast-C5
I was able to clear the codes, but it keeps popping up every time I start the car now! Has anyone ever had the code for IAT Sensor High Voltage? If so how did u fix it?
Thanks!
Sean
Old Jul 19, 2005 | 09:22 PM
Fast-C5's Avatar
Fast-C5
Anyone?
Old Jul 20, 2005 | 09:03 AM
Wah's Avatar
Wah
Did you try replacing it ? I believe in 2000, the IAT is separate from the MAF.
Old Jul 20, 2005 | 09:27 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I guess you are referring to P0113? If so, here is the diagnostic procedure:
http://www.gearchatter.com/viewtopic8617.php
GL!
Old Jul 20, 2005 | 10:01 AM
Fast-C5's Avatar
Fast-C5
Yeah I tried replacing it, No fix. It does not effect the performance but just makes me clear it out everytime I restart the car.
Old Aug 16, 2005 | 03:41 PM
Fast-C5's Avatar
Fast-C5
Finally had the time to take it in to the mechanic, Very simple problem, the wires going to the pigtail connection on the IAT sensor had come loose, it was reading -38 degree's so that also was making my Active handling warm up. All is well.
Thanks guys!
Sean
To Check Engine Light????
