Must have tool list
I picked up the following so far:
-137-piece Craftsman Mechanic's Tool set (ratchets, sockets, allen wrenches and wrenches mostly)
-16 piece Craftsman Mechanic's screwdriver set (Flat Head, Phillips, close range flat + phillips)
-11" Vice Grips
-4-piece pick set (has hooks for pulling retaining clips, etc)
-Wire Stripper
Are there any typical tools I need to do the basics? I need to get some sort of universal joint and extender perhaps for pulling spark plugs? Do I have everything needed to strip the interior out for installing sound/heat insulation?
Thanks,
UT-Driven
Hope this helps and good luck.
hmm..jacks/jackstands if you don't already have them. I picked up some pretty nice/cheap aluminum jacks from walmart that are the best i've seen for the price.
Sounds like you got a decent start on tools. I've found that a tool chest that rolls around is basically the only way I can keep up with all the tools. That way I can just throw them all in one place and roll it around when I need them
Something I have found INDESPENSIBLE is a compressor and an impact wrench. The compressor was ~$150 and the impact wrench $100 from sears. Once having used these, I don't know how I got by without.
-11" Vice Grips
-Wire Stripper
Thanks,
UT-Driven
The tool you need is always the one you don't have. I hope your set has a good selection of metric sizes. I would add a set of deep well metric sockets that includes 21 and 24 mm sizes as some of the stuff is large. Good luck collecting tools can get expensive. Jeff
Gator ramps (whatever those $30 things from pep boys, awesome)
Modified shorty spark plug socket for #7 (guy sells them on eBay $5)
Insulated battery wrench, long handle (8mm i believe, any parts store)
You need two torque wrenches actually something like 20-250 inch#s(3/8" drive) and a 25-250 foot#s(1/2" drive). Make sure they are reversible. Worth spending some money on Snap-On here.
Telescopic magnetic retriever, very useful, also use mine to relearn tire sensors.
Didn't see floor jack yet, so get one thats as low as possible. Two if you can swing/store it.
Fuel line disconnect tool (low cost any auto parts store, get a set)
Other than that, just beer, music and wife repellant... Good Luck!
You will need:
Metric tools - standards aren't common on the C5
both sockets 1/4, 3/8 & 1/2 inch drives and combination wrenches(box/open end wrenches)
Torx bits - either individual screwdriver type, or torx bits for a socket wrench
Torque wrenches - both inch pound and foot pound readout - as advised, spend some money here to be sure you get accurate tools
jack stands - 2 will work, 4 are PERFECT - allows lifting entire car - you can substitute a set of car ramps for one set of jack stands, and I've found using ramps at one end of car, and jacks at the other end works well.
1 rolling hyd jack - 2 work even better
jacking pucks - pieces of wood will work, or make yours out of hockey pucks
Maybe a ball-peen hammer or two
eventually, you may want a few pry bars
if you're going to remove door panels, you will want door panel removal pliers/tools (only takes two different tools) and a "Christmas Tree" removal tool for removing "Christmas Tree" fasteners.
Air compressor and impact tools are nice, but they wouldn't be the first thing I'd purchase - you can do almost all of the work you want to do without them. Also, if you get an impact wrench, be sure to get impact sockets - IE: don't use regular (chrome) sockets with an impact tool -
Pliers - both needle nose and regular - I prefer "Channel Lock" style pliers (either Channel Lock brand or something similar) over a regular slip joint pliers, and I've got them from 3-4 inch size up to approx 16-18 inch size.
Also, a side cutter plier is useful.
Flex Head Gear wrenches - I don't yet have a set, but I've been using them at the body shop where my car is getting finished, and I've really started LIKING them. - Wouldn't be my first purchase, but I'm gonna get a set.
floor creeper for rolling around underneath the car
a trouble light - I simply prefer an electric trouble light over a flashlight - both is best
oil catch pan - get one that is capable of holding AT LEAST 2 quarts MORE than the max capacity of your engine - I hate draining oil and the oil completely fills the catch pan - when this happens, guaranteed you will spill oil on your floor getting the oil pan out from under the car.
2 1/2 gallon or larger container - can be a gas can or simply a used, empty 2++ gallong plastic jug - use it for collecting your used oil - when you change oil on your car, lawnmower, etc, drain it into your oil catch pan then poor it into this container - then you only have to run dump the oil when your container is full.
portable and a larger tool box - sounds like to begin w/ you can get by with a portable (hand carry) type tool box. Get it bigger than you initially need, cause YOU WILL fill it up, and YOU WILL run out of room. Portable tool box also nice for tossing just a few tools in to take w/ you on trips. While it's not initially required (spend your money elsewhere to start w/), if you keep gathering tools, you will eventually want a roll around, chest type tool box similar to what Craftsman, home depot, etc sell.
beer, music and wife repellant - nuff said - if you've got a Vette, tools, beer, music and wife repellant, you have a GUARANTEED cure for even the worst day or week in your life - take these items, immerse yourself in the project at hand, and forget about the days/weeks troubles - AH, Bliss!
Finally, you don't have to purchase Snap On/Matco, etc as they do tend to be spendy - watch ebay and sometimes you can get some deals. I've got some Craftsman also, lots of guys on the forum use them, and they are good tools.
Stick with American made tools, Craftsman is a good choice, "Allen" brand, SK brand, Proto brand, Snap On, Matco, Mac, etc. The more you start working on your car, the more you will find yourself using tools, so get good ones to begin with rather than buying cheap and then having to replace them as they break/wear/you become more serious, etc.
HAVE FUN!!
A must have there!
