Torque Tube Questions
One, is it possble to inspect the couplers with taking the tube out and apart?
Second, it seems that I read somewhere that you need put bolts in the front of the tube to maintain alignment of the driveshaft when removing the tube or is that only for stick cars?
Thanx in advance. Jeff
http://forums.corvetteforum.com/show...aft&forum_id=1
I never put any bolts in when removing mine and its a stick.
Also make sure you check the bearings on the rear of the driveshaft.
