dic code
Old Jun 29, 2005 | 08:18 PM
jpc0011's Avatar
jpc0011
Default dic code
Checked for code and have the following:
C1235 RR Wheel Speed Circuit Open or Shorted. What do I look for? Where? anyone. Thanks
Tried to clear will not clear?
Old Jun 29, 2005 | 09:50 PM
jpc0011's Avatar
jpc0011
Ok, I am desperate. Why cant I clear the code?
Old Jun 29, 2005 | 10:06 PM
LoneStarFRC's Avatar
LoneStarFRC
If it's a "current" code and rated high enough on the safety scale of things, it may very well not clear (at least not by the DIC). Some codes can only be cleared using a scan tool or if the problem goes away and stays away for a certain number of drive cycles. Try checking you wheel speed sensor harness and connector on the R/R wheel. See if it's loose or disconnected. See if it looks damaged too. Try unplugging it and checking for any foreign material/dirt that may have gotten into the plug or any signs of water/moisture entry (corrosion for example). HTH
Old Jun 29, 2005 | 10:15 PM
jpc0011's Avatar
jpc0011
Took a look under r rear wheel and found problem. The two small spagehtti wires are severed from presumably the sensor? I must have ran over something? Can I just order sensor and rewire? Thanks
Old Jun 29, 2005 | 10:20 PM
jpc0011's Avatar
jpc0011
Can someone please tell me how to id the damaged part? Is is the wheel sensor? a/h ? traction? abs? need help so I can order new part asap....
Old Jun 30, 2005 | 09:53 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If the wires have severed you may just be able to solder them back together???
If they have severed to close to the plug to make soldering impractical then just take the plug to the dealership and tell them that you need a replacement, it will be a new plug with about 18 inches of wire.
Old Jun 30, 2005 | 11:09 AM
feeder82's Avatar
feeder82
you can try looking up the part on gmpartsdirect.com they use a body shop catalog that has great illustrations
Old Jun 30, 2005 | 01:28 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
How do you get to this catalog?
The only catalog I've seen on their website is the Mitchell catalog and it sucks [b]BIG TIME!!!]/b]
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The only catalog I've seen on their website is the Mitchell catalog and it sucks BIG TIME!!!
Old Jun 30, 2005 | 06:49 PM
jpc0011's Avatar
jpc0011
Called fredbeans, was able to buy new speed sensor connector 20.90 shipped. The wires were sheared to close for rpr. Ok to just solder onto existing wires from hub? Thanks
Old Jun 30, 2005 | 07:00 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Yep, it's ok
The last time I pulled my rear and tranny I forgot to disconnect the VSS connector and pulled both wires out of the back of the connector, $35.00 later and a little solder it was as good as new.
Old Jun 30, 2005 | 07:13 PM
LoneStarFRC
Glad you found the problem. I would also strongly recommend that you use a good length of shrink tubing over the repair if you have to do any soldering. Moisture/corrosion has a way of getting into things, especially components that are located under the car. HTH
Old Jun 30, 2005 | 08:57 PM
jpc0011's Avatar
jpc0011
Thanks, appreciate the assistance. Picked up shrink tube today from the home depot. Hope to have part tommorrow and its back in action.
To dic code
