ARP Wheel Stud Part# ?
Old Jun 30, 2005 | 11:57 AM
DT's Avatar
DT
Default ARP Wheel Stud Part# ?
Howdy Folks!
Anyone know the part# (either ARP or vendor like Summit) for ARP replacement wheel studs?
I snapped one several weeks ago, and figured I'd replace them all with upgraded parts. I track the car a few times a year, plus I'm going to be going FI, so I figure the extra safety/security of better-than-OEM couldn't hurt
Looks like Summit has them for roughly $60-65 for all four corners.
Is there a slightly longer stud? I know with my CCW track wheels have thicker hubs/centers, so I don't think the stock studs/lugs get as many turns as the stock wheel setup.
I appreciate any information
Old Jun 30, 2005 | 01:42 PM
AU N EGL's Avatar
AU N EGL
Yup I have the ARP longer wheel studs to put on the 3/8 spacer I need for my rear CCW 12" rims
Summit Racing
ARP-100-7702 3.2" long
$10 for a pack of 4
Old Jun 30, 2005 | 04:13 PM
kromberg's Avatar
kromberg
How hard are they to install?
Keith
Old Jun 30, 2005 | 04:23 PM
DT's Avatar
DT
AU N EGL -
Excellent thanks! I figured someone who tracked their car would know and/or have done this!
Yeah, they're so cheap is seems like a no-brainer. Will the extra length create any problems with factory wheels and factory (closed end) style lugs if you go _back_ to stock wheels?
kromberg -
I understand it's a bit of a PITA For the rears I guess you don't quite have enough clearance without removing some additional components. I just happen to be doing a full set of brakes, and probably my '04 Z shocks as well, so I figured this would be a good economy-of-labor
FWIW, my dealer who usually cuts me pretty good labor breaks, quoted me ~$300 for all 20 studs to be replaced and to swap all 4 rotors (and pads if I want). So 4-5 hours seems semi-reasonable (I'm sure when I'm 30 hours into it, I'll feel differently )
Old Jun 30, 2005 | 04:56 PM
AU N EGL's Avatar
AU N EGL
Fronts are easy to install rears are a PIA as you have to remove a few things.
IF you use these you will need open ended lug nuts. I bought mine at NAPA. The OEM lug nuts will no longer fit.
To ARP Wheel Stud Part# ?
