Power Loss
Old Jul 1, 2005 | 01:32 PM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
Default Power Loss
Coming Home today I passed a car. I gassed it and it took off like normal but when I got up to 80 it just bottomed out no more power. Did it again a little later. Under a slow acceleration it is no problem it goes. Just when I get on it. No codes thrown. Any ideas would be welcome.
Old Jul 1, 2005 | 03:56 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sounds like it could be a fuel pressure issue. The very first thing that you need to do is change the fuel filter! If that doesnt fix it, you may have a fuel pump issue. If you can fine a fuel pressure gauge with a long enough hose, you could monitor the pressure when you are under full throttle and see if it drops low.
Bill C
