HVAC Vacuum Reservoir
Old Jul 3, 2005 | 05:58 PM
Speedway's Avatar
Speedway
Default HVAC Vacuum Reservoir
Due to air delivery problems, I decided to attempt the diagnosis myself. Upon inspection of the vacuum reservoir, I found three lines, one of which is corroded and cracked and appears to be the engine vacuum line. I know where the second line goes.....where does the third go? The service manual only indicates two vacuum lines.
Unfortunately, the engine vacuum line split somewhere between the manifold and reservoir and I am unable to find the other end. Could someone tell me where the other end is on the back of the manifold?
Thanks in advance.
Old Jul 3, 2005 | 08:09 PM
purrvert's Avatar
purrvert
Vacuum line comes from MAP sensor on the firewall side of the intake, right hand side, large brake boost line also comes from the MAP. The third line goes to the secondary air solenoid mounted on the right hand frame between the top of front fender and frame, fastened by one bolt, very hard to see.
Old Jul 3, 2005 | 10:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The tank has three fittings One goes to the HVAC controllers inside the passengers foot well:
one is the vacuum supply line from the back of the manifold:
The other one goes over the the AIR pump which is located under the drivers side head light assembly:
Bill C
Old Jul 4, 2005 | 01:41 AM
Speedway's Avatar
Speedway
Thanks for all the help. I'd sure like to know who the genius was that decided all critical components should be placed under a battery. No brain no headache I suppose.
Old Jul 4, 2005 | 07:09 AM
Midwest Vette's Avatar
Midwest Vette
I am making the same repair to my 98 coupe, I found 2 of the vacuum lines cracked on mine. Good luck with the repairs.
Old Jul 4, 2005 | 04:39 PM
Speedway's Avatar
Speedway
Well, I had horrible luck with the repair. Problem still occurs.
What shall be my next approach?
Old Oct 3, 2021 | 08:43 PM
Beach18's Avatar
Beach18
7th Gear
What should the suction pressure be at that map sensor nipple for the ac?
My 2000 C5 LS1 is showing only 6psi and may be why my ac vents are not functioning as they should. Should I being seeing approx 20psi?
Old Oct 3, 2021 | 09:00 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Didn't you just post your issue in another thread ??…which one do you want deleted ??…as I mentioned you should not be seeing psi…vacuum is read in inches of Mercury..and yes if your manifold vacuum is 18-22 inches you should be seeing that !!
To HVAC Vacuum Reservoir
