My 99 Vert passenger side window is rubbing against the top at the upper left of the window. If I lower the window ,close the door than raise the window it fits right. If the window is up and close the door it pinches the corner of my top. Can I fix this myself?? Thanks
Mine does the same. The previous owner had the top adjusted and it's just not right. I've used the faq to adjust the top -- it's better but I can't seem to get it 100% perfect. Window valet is a godsend with this problem, by the way...
Let me know if you're able to fix it and what exactly your measurements are on those adjustment bolts.
So if I understand correctly I need a Window adjustment not a top adjustment??
No, but now that I have the window valet, I can just hit the windows down and then back up instead of messing with the top -- it's not a fix, just a way to procrastinate fixing it completely. You still have to adjust the top to correct your window problem.
