Service ABS, Active Handling, etc.
Old Jul 5, 2005 | 11:42 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Service ABS, Active Handling, etc.
I have gotten this before, mostly when I had been parked on an incline but I have been getting this more and more backing out of my garage. Simply cycling the key removes the messages and there are no current DTC's.
Could this have anything to do with my lowering it?
Is there any common part that goes bad that could be causing this?
Old Jul 5, 2005 | 01:17 PM
MRSBHVN's Avatar
MRSBHVN
6th Gear
Default Service ABS and active handling
I would be interested as well to hear what others have to say about this because I am getting the same thing whenever I back out of my garage. I am always able to clear the code but it sure does get annoying. I have read that switching out batteries to an Optima may help.
Deonne
Old Jul 5, 2005 | 01:56 PM
5 Liter Eater
St. Jude Donor '11
One thinig I have read to ensure that the ground wire in the driver's rear wheel well is tight and clean. I need to check that as well as my history codes. It's certainly not happening every time but it is fairly frequent.
Old Jul 5, 2005 | 03:39 PM
f430killer's Avatar
f430killer
I just went through this, heres a link to my story.....
http://www.zo6vette.com/forums/showthread.php?t=79910
Old Jul 12, 2005 | 05:50 PM
5 Liter Eater
St. Jude Donor '11
Happened again to me today. This time I checked the codes before cycling the ignition and I had a current code:
C1226 RF Excessive Wheel Speed Variation
To Service ABS, Active Handling, etc.
