Is Sportbrakes still in business???
Cruise-In IV Veteran
Cruise-In V Veteran
I have tried calling and e-mailing them for two days and no answer and no response. Are they taking an extended Fourth of July holiday or something? Has anyone been able to get a hold of them recently?
I would like to talk to them about getting some rotors for my car but if I can't get in touch with them it makes it difficult.
I had the same problem 2 weeks ago. I finally gave up and contacted Rotorpros.com. He called me back and has answered the phone. The rotors were shipped and they are now on the car. I got tired of waiting for Sportbrakes to even respond. I know they make a good product but I perhaps they are on extended vacation? Good luck!
Mark
Mark
Usually, if I have to wonder whether or not a business is still operational and they don't answer the fone, I assume they aren't, and go someplace else. I am really reluctant to send money some place that is consistantly unreachable during normal business hours. JMHO.
My dealings with them went very well. Great prices and they arrived at my door when they said they would.
While your waiting, it wouldn't hurt to research other sources!
Someone on here should help....
1 Post
Been to the Sportbrake shop in Dallas, they are a two man shop. Sometimes it takes them a while to respond, I had that problem so I drove to their shop to place my order.
Those guys have huge volumes so it takes them some time to get back you depending on what they are producing. Let me know if you want me to run to the shop and check if they are still operating.
1 Post
I am in Dallas and got mine also AT THE SHOP (The shop isn't a Shop, it is more like a rented metal stprage space in a strip center like).
There is abasically 1 guy there who runs it and you just need ot be patient. If he is out getting a cheesburger, his accountants and warehouse personal and customer service people aren't gonna help you....................cause he ain't got any
Keep trying, you'll get through. I think he used to sell on e-bay too so check there.
Cruise-In V Veteran
Thanks for the replies guys. I'll keep trying cause it seems like they offer a very good product, just would have liked to get them ordered this week. Might go with Zip Products rotors if I can't get a hold of them.
Cruise-In V Veteran
Originally Posted by 03Ragtop
If they'd just fix the 'shopping cart' on their website, they wouldn't have to answer the phone so much.
Bought mine 2 weeks ago.
Same thing happened as I called several times w/o a reply. Fortunately, I called right at about 9:00 AM Central time and got through. Rotors were sent out the same day and delivered as promised for 250.00
These zinc rotors are from Canada. Looking now for a supplier up there to maybe get a better price.
Ill post if I do.
Good luck,
Mike
Ill post if I do.
Good luck,
Mike
Cruise-In V Veteran
Ill post if I do.
Good luck,
Mike
Ill post if I do.
Good luck,
Mike
CI 4-5-6-7 Veteran
Congrats! I still get compliments on mine 6 months and many track events later. Here's a tip: Don't use Mequires wheel cleaner after installing these rotors. It will stain/etch the coating.
CI 4-5-6-7 Veteran
Originally Posted by 98vert6spd
anyone know if theres a warranty on these cause mine are warped now
I ve had them on the car form about 7 months and mayube 6k
i dont know
I bougth the ceramic pads too
my car is a vert
I dont track it or really get on brakes hard
the only thing i can come up with is the stickers you put onthe pads
the pads come with an adhesive sticker that you put on the back of the pad
hell i dont know what its supposed to do
but anyway i put them on all 4 pads and then last moth i noticed they had lost there adhesion and they were trying to come off
granted they are pinned between ther caliper piston and the pad but somehow they managed to get out on part of the pad
I suspect that the few thousanths that the sticker is caused the piston to apply more pressure to one side of the pad and that helped to warp the rotor
its not warped all that bad but you can feal it
the rears are still good but the sticker came off back there too
id advise people to not put those stickers on the pads cause i can see no reason for them and they just fail and get loose after you wash your car a few months later
my car is a vert
the sitckers came with the pads that sportbrakes sold me
they were installed just as the directions explained and everything was torqued to spec
they were installed correctly is the point
the stickers (supplied with the pads (sold by sportbrakes)) came off the pads, most likely causing the rotors to warp IMO
of course it could also be a faulty rotor
who knows
i was just presenting a possible scenario that might result in a warped rotor
maybe that explains it better
I was simply asking about a warranty though
rotors from autozone or advance auto usually have like a 1 yr warranty
who knows
