Help my A/C is roasting!!!
Old Jul 6, 2005 | 09:13 PM
Pewter Tex's Avatar
Pewter Tex
Default Help my A/C is roasting!!!
Yesterday my A/C was blowing so cold I adjusted the Memory setting up a few degrees. Today, it was blowing so hot I was sweating at 7 am and it was cooler outside. The A/C button light flashes when I push it. I checked the hoses and they look ok, check all the fuses and relays and they were fine. Anyone have any suggestions? What could cause it to go in 1 day???
I've got a newborn and really can't afford to pay a stealer excess $$$ to tell me what's wrong if it's a relatively inexpensive fix.
Thanks,
Chad
Old Jul 6, 2005 | 09:35 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
What does the outside temp read ? If that sensor goes bad it will prevent the A/C from working
Old Jul 6, 2005 | 10:00 PM
NoWay's Avatar
NoWay
Chad, get under your radiator and see if it is cluttered with "stuff". Make sure it is clean. I had the passenger side air vents blowing very hot air and as soon as I got the plastic bag out from the radiator cavity, all was okay again. It's worth a try.
Old Jul 6, 2005 | 10:01 PM
Pewter Tex's Avatar
Pewter Tex
The outside temp reads F*cking HOT!!! It's July in Austin, Texas. It seems to be fairly accurate right now, it says 100 in the garage which seems about right the current temp according to our local station is 98.
Old Jul 6, 2005 | 10:12 PM
Pewter Tex's Avatar
Pewter Tex
Strike 2. The radiator's clear.
I'm getting a really bad feeling this is going to cost me big bucks
Old Jul 6, 2005 | 10:15 PM
navy99vert's Avatar
navy99vert
look in the owners man. and pull the fuses for the A/C. this will reset the system
Old Jul 6, 2005 | 10:21 PM
Pewter Tex's Avatar
Pewter Tex
Do they have to be out for a specific length of time? I've pulled all of the fuses (and relays) and they were fine.
Old Jul 6, 2005 | 10:28 PM
navy99vert's Avatar
navy99vert
Check for codes then post what you find. Sometimes clearing them will help, but wright them down first
https://www.corvetteforum.com/techti...D=25&TopicID=1
Old Jul 6, 2005 | 10:37 PM
Pewter Tex's Avatar
Pewter Tex
No current codes
Thanks everyone for your help. I'll keep checking as long as you've got ideas
Old Jul 6, 2005 | 10:58 PM
navy99vert's Avatar
navy99vert
Originally Posted by Pewter Tex
No current codes
I'm out of Ideas Maybe someone else has the can help
Good luck It's to hot to be without A/C. My work truck doesn't have it an IT'S HHHHOOOTTTT
Old Jul 6, 2005 | 11:04 PM
George8211's Avatar
George8211
If your air conditioning light is blinking .... something is wrong. If your water temp is high, most likely you will need to remove and clean the radiator. Lots of dirt gets in the fins that you can't see by just looking at it from under the car. If your running 230+... be ready to pull the radiator.
Old Jul 6, 2005 | 11:06 PM
navy99vert's Avatar
navy99vert
Does the compresser come on when you turn the A/C on? If it doesn't you mightbe low on freon. You can buy it youself and recharge the system
Old Jul 6, 2005 | 11:17 PM
Pewter Tex's Avatar
Pewter Tex
How would I know if the compressor comes on?
Old Jul 6, 2005 | 11:31 PM
DanTTVette's Avatar
DanTTVette
Hi Tex
The last time I saw the flashing AC light was after leaving the A/C refrigerant pressure sensor disconnected. Compressor will not run if there is a fault here. The sensor is just below and in front of the coolant reservoir tank on the passenger side.
So firstly, check the wiring and the sensor.
Can you say if the fans are running? Without fans, high pressure will switch off the compressor.
If your 134A has leaked out, pressure will be too low, same result.
Interestingly, if the freon has been leaking out of your system, there will be a brief period where the system will actually kick out very cold air as pressures are so low in the system. This ties in with your description.
Unfortunately, with these low temps and Texas humidity, the evaporator will ice up, eventually blocking airflow.
System will eventually quit altogether.
Without the system running, you will need some gauges to check the static pressure.
Owners manual indicates that you should expect to see 100psi @ 90 degrees air temp with the system off (either the high or low side...)
Low-pressure access is near bulkhead by the battery on the passenger side.
Check all visible pipes, condenser etc for an oil stain. This may help indicate location of the leak.
Let us know
Good Luck
Dave
Old Jul 7, 2005 | 10:18 AM
t56gen3's Avatar
t56gen3
If it was working one day and not the next, I'd say you probably don't have a refridgerant issue. Assuming the compressor isn't kicking on, I'd check the low pressure switch first, they are inexpensive to replace. You should be able to pull the harness and jumper the pins with a paper clip. If the compressor kicks on and works fine then the switch is likely bad.
To Help my A/C is roasting!!!
