LS2 oil pan
Old Jul 8, 2005 | 11:52 AM
SteveDR425's Avatar
SteveDR425
Default LS2 oil pan
Does anyone know if you can run an LS2 oil pan in the C5?
I will be putting in a 402 LS2 in my car soon and was wondering if putting in a
new LS2 oil pan is worth the extra $300+ .
Old Jul 8, 2005 | 12:38 PM
NSTG8R's Avatar
NSTG8R
not a 100% positive but i believe they changed the design of the oil pan when they did the ls2
Old Jul 8, 2005 | 01:13 PM
SteveDR425's Avatar
SteveDR425
From what I was reading it is a better design to control oil when roadracing/autocrossing. Here is what I could find on it.
"For Corvettes, there's an all-new oil pan design. It eliminates the winged style of the LS1 pan as engineers devised a better internal design to fight high-g oil starvation. New-design baffles inside the Corvette's oil pan are designed to keep the oil pump pickup submerged in oil during high-load cornering maneuvers. The elimination of the previous-style pan's wings also reduces the oil capacity of the pan by one quart. "
http://www.gmhightechperformance.com...s/0405htp_ls2/
Old Jul 8, 2005 | 07:41 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Won't fit.
Old Jul 8, 2005 | 09:21 PM
RoadRebel's Avatar
RoadRebel
Hrm..I luv the internet..
It fits like a glove and provides a tone of extra clearance. Done it twice now.
If you going with LS1/lS6 short block you reuse the oil pickup tube and have to transfer over the oil level sending unit and cover. The cover is the piece that bolts to the pan by the oil filter and holds the temp sender. You will also have to purchase a new dipstick and tube.
Phil
Old Jul 9, 2005 | 08:27 AM
SteveDR425's Avatar
SteveDR425
Phil
So, since it will work, it is worth the $300+ dollars to get it?
I will be running the LS2 block.
Old Jul 9, 2005 | 12:49 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Phil....
These guys are keeping you busy on the whole LS2 pan thing
Thanks to some advice from Phil (Road Rebel) and a few others I have decided to do the swap. My decision is more from a standpoint of ease of engine installation (from the top) that the new design pan provides due to the fact I have a few different engine configurations I will be installing (featuring AFR heads of course) over the next 3-18 months or so.
Also, I personally like the fact it is better at transfering oil backwards (when your accelerating in a straight line) because I am more a drag racer that a road racer. Lastly, saving a few pounds is always a bonus and I would guess theres a decent weight savings with the LS2 style pan.
I will let you guys know how the swap goes in a few months when I drop the new 383 I will be dyno testing in early August (flywheel dyno) back into my vehicle.
Tony M.
Old Dec 15, 2010 | 03:12 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
OK, I know this is an old thread, but I need answers to a question ASAP.
I just bolted up a new LS2 oil pan on my LS1 motor. Everything fits PERFECT.......
BUT there is one extra hole on the drivers side oil pan mating surface that the block doesn't have a hole for. It is in the middle between the rear of the pan and the front of the pan, so I would assume it wouldn't make much difference, but thats just an assumption.
Can any of you guys who have done the swap tell me if it needs to be drilled or leave it like it is.
To LS2 oil pan
