Cyclical vibration at high speeds.
Old Jul 10, 2005 | 04:23 PM
Turbooo2u's Avatar
Turbooo2u
Default Cyclical vibration at high speeds.
I have a vibration that comes on at higher speeds and at a constant frequency. It occurs about every 2 seconds and lasts about a half second. Any thoughts?
Old Jul 10, 2005 | 04:45 PM
Patches's Avatar
Patches
Sounds like a bad wheel bearing to me.
Old Jul 10, 2005 | 05:45 PM
JTS97Z28's Avatar
JTS97Z28
Thats exactly what mine does around 53mph. Started after I had new rims and tires put on.Since then I have had new wheels shipped to me and will try to figure out if its the tires or the actual rim thats out of balance.
Sounds like you have wheel balancing issues not wheel bearing problems.
Old Jul 10, 2005 | 06:10 PM
shakainc's Avatar
shakainc
Mine did the same thing. Ended up being a bent hub. Dealer replaced it under warranty.
Old Jul 11, 2005 | 07:44 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I had a similar vibration after going to the AC Delco sport rotors. I switched the rotors out and the problem went away.
Good luck,
AZC5
To Cyclical vibration at high speeds.
