A/C vacuum problem - need diagrams
Old Jul 10, 2005 | 06:56 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Default A/C vacuum problem - need diagrams
I believe that I have a problem with the vacuum that controls the vent door on my A/C. I've read a number of threads regarding this problem, but was wondering if anyone has any of the factory diagrams/or pics showing the location and process for checking and fixing this problem. Thanks for your help. Zuti
Old Jul 11, 2005 | 01:29 AM
Speedway's Avatar
Speedway
Zuti,
Take a look at these two:
http://webpages.charter.net/bshadel/...uum%20tank.jpg
http://webpages.charter.net/bshadel/Misc/diagnostic.htm
I just repaired my vacuum lines over the weekend. System works great now.
If you need additional help, please send me an email at bshadel@charter.net and I will be happy to help as best I can.
Bryan.
Old Jul 11, 2005 | 03:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your problem stems form the fact that you have no vacuum to the HVAC vent door controlers. The vacuum for all of the C5 vacuum systems comes from the back of the intake manifold here:
The vacuum line is constructed of a small black nylon tube that connects to that fitting with a rubber 90 deg boot. From there it enters one of the main wiring hanesses and then goes down to the vacuum tank in the passengers foot well.
You can use a mirror to inspect the intergity of the intake manifold connection. It is a ROYAL BITCH to get to without taking the manifold off!!
An acid leak fron the battery can and will eat up the vacuum line in the harness and can cause this condition. Also if the connection on the manifold or tank is off it will do the same.
Bill C
Old Jul 11, 2005 | 09:38 PM
Zuti's Avatar
Zuti
CI 6-8-9 Veteran
Thanks for the help guys. I'll check it out tomorrow night. Zuti
To A/C vacuum problem - need diagrams
