considering the C5
Old Jul 12, 2005 | 07:00 PM
danelectro's Avatar
danelectro
Default considering the C5
I just sold my 96 C4 last Sat. and I'm considering a C5. I really wasn't expecting to buy a car this soon but I can buy a 2000 coupe automatic with 34k tomorrow for $22.5K.
Anyway I don't know the specifics on the 2000 but really wanted to buy a car with the beefy Z51 suspension. If the car is not equiped can a conversion be done later. Would it even matter for in town (on city streets) driving.
Old Jul 12, 2005 | 07:10 PM
Irish Whiskey's Avatar
Irish Whiskey
Have 2000 coupe-A4-3.42 gears,hardened shaft, blackwing, Kooks headers - 1 3/4" feeding through high flow cats and xpipe into Corsa Indy Tigersharks. Racing Concepts rotors and pads -drilled and slotted. LS6 intake manifold.To be done: Yank SS3600 TQ.
Time in 1/4 mile: 12.8/ 110mph -- road circuit race: yes, and it is a blast as I have the Z06 sway bars, but might have gone with Hotchkiss if doing it over. Need to drop the car about an inch as well. Might look into Bilstein shocks,but need to study more.
Have put 10.5" chrome wheels on back so I can go from 275/40/18's up to the 305's.
Old Jul 12, 2005 | 07:13 PM
danelectro's Avatar
danelectro
Is 3.42 the highest stock ratio or were the cars offered with wimpier ratios.
Old Jul 12, 2005 | 07:35 PM
JH's Avatar
JH
Now, now. Let's not cast aspersions on those of us who have the lowly 3.15 rear ends. Actually the 3.42 was an aftermarket add-on, I suspect.
I'd say when you get the right car for you, jump! I also made the move from a C4, though earlier than yours. I thoroughly enjoy my '02.
Old Jul 12, 2005 | 08:15 PM
danelectro's Avatar
danelectro
I actually would prefer a higher ratio, I'm not a racer. My C4 was easily the best per mpg car I've ever owned and was plenty snappy for me with its 2.70's. The 28 mpg on trips was swell.
Anyway Z51, worth the search or not. I have until tomorrow to decide.
Old Jul 12, 2005 | 10:20 PM
CliffB-99's Avatar
CliffB-99
You can upgrade to the Z51 or Z06 suspension pretty easily from the base suspension. If it has the "real-time dampening" (aka select-a-ride) suspension, the Z-51 shocks do not work with that option, but you could put Z-51 the sway bars/springs on. Bottom line, suspension is easily upgraded for reasonable $$.
Here are some upgrade packages from GMPartsdirect.com
F/R Swaybars:
http://www.gmpartsdirect.com/results...r=PKZ06STABKIT
Shocks:
http://www.gmpartsdirect.com/results...=PKZ06SHOCKKIT
Rear Spring:
http://www.gmpartsdirect.com/results...umber=22188038
Front Spring:
http://www.gmpartsdirect.com/results...umber=22178729
Old Jul 12, 2005 | 10:55 PM
shurite44's Avatar
shurite44
The A4 comes with the 2.73 and performance axle 3.15 all M6's are 3.42s from the factory.
Old Jul 12, 2005 | 11:20 PM
JH's Avatar
JH
I easily get 26 -- 28 mpg on the highway (if I behave) with the 3.15. LIke you, I knew I wanted a later model C5. I decided on the '02 or EARLY '03 because all the goodies and fixes (that GM decided to do) were in. I avoided anything later than mid-model year '03 because new regs from the EPA forced GM to put the fuel filter INSIDE the tank. Having had a few fuel filters that needed changing through the years, I decided to avoid one needlessly expensive procedure.
To considering the C5
