Deep Pan For C5 A4
Old Jul 12, 2005 | 11:35 PM
INTHERED's Avatar
INTHERED
Default Deep Pan For C5 A4
I just got my new Summit Racing catalog and noticed that they now have a finned aluminum pan for the A4 guys that holds 2 extra quarts. So now ya know as much about it as I do.
INTHERED
Old Jul 13, 2005 | 02:46 AM
LS9's Avatar
LS9
I've seen those before and would rather use a cooler than have a cast pan that will crack if it hits anything.
Old Jul 13, 2005 | 07:08 AM
XTrooper's Avatar
XTrooper
The fear of bottoming out and cracking a deep pan would steer me from this idea. Besides, it's so easy, inexpensive, and effective to install a tranny cooler on our cars that there's no reason to look for other solution.
Old Jul 13, 2005 | 10:02 AM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Not worth the worry of bottoming out over a speed bump or some other obstruction and knocking a hole in the pan. Lose all the transmission fluid while you are driving and your tranny is shot in a matter of minutes.
Old Jul 13, 2005 | 11:30 AM
b98's Avatar
b98
Old Jul 13, 2005 | 01:29 PM
INTHERED's Avatar
INTHERED
I still think its worth taking a few measurements to determine if that is a problem since its got to be easier then installing a trans cooler. Plus it might be designed with both a side fill and drain plugs which would make changing fluid a lot easier.
INTHERED
Old Jul 13, 2005 | 05:22 PM
gojo's Avatar
gojo
INTHERED
I have a deep pan as an added precaution. It will not replace a tranny cooler. I don't have my car or I would take a picture.
The pan is not the lowest point. You will not hit anything that clears the front. Your oil pan is more likely to be hit. Your frame would hit a speed bump, not the pan.
Old Jul 13, 2005 | 07:54 PM
LS9's Avatar
LS9
having seen road debris crack cast pans, I'll pass on it
Old Jul 14, 2005 | 01:22 PM
INTHERED's Avatar
INTHERED
Did your deep pan have both a drain plug and a fill plug ?
Old Jul 14, 2005 | 03:19 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
INTHERED
Bottoming out, no way!! I have both the deep dish and a tranny cooler that work very well for me for years. Plus I am lowered in the front and rear.
Old Jul 14, 2005 | 04:44 PM
gojo's Avatar
gojo
Al,
Glad you had a picture. It's nice to get firsthand feedback.
Joe
Old Jul 15, 2005 | 12:59 AM
LS7 C5's Avatar
LS7 C5
I have a new finned trans pan that holds
four extra quarts and has drain plug. paid
190.00 bucks for it. I chickened out and
didn't install it on my lowered car. will sell it
for 125.00 plus shipping. if interested e-mail me
michaelsgarland@sbcglobal.net
Old Jul 15, 2005 | 10:57 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Not to mention losing all of your tranny fluid will not kill the transmission it will just make it inoperable until it's reserviced.
BTW to service a rebuilt transmission you have to start the car and then pump in fluid and then let that warm up to operating temp and then service it to the proper level.
Old Jul 15, 2005 | 12:03 PM
LS9's Avatar
LS9
I'm not worried about bottoming out. I've had cast pans crack from debris hitting the pan.
Old Jul 15, 2005 | 01:58 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I remember a rock hiting someone stock tranny pan on a mountain caravan back in 2000. His tranny temp went up real fast and he was forced to call a tow truck.
Old Jul 16, 2005 | 03:25 AM
LS9's Avatar
LS9
A stock pan will flex alot and dent before it leaks. A cast pan just cracks, no flex at all.
To Deep Pan For C5 A4
