Bosch Plat+4 = HP increase
Old Jul 13, 2005 | 07:36 AM
AJay's Avatar
AJay
Default Bosch Plat+4 = HP increase
This months Corvette Fever Mag article in Tech Line page 82 makes the statement that Bosch Platinum Plus 4 Spark Plugs will add 6-8 HP. Can anyone substantiate that claim?
Old Jul 13, 2005 | 08:02 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I dont see that happening... Dont waste your money on plugs and expect to see HP gains.
VR
Old Jul 13, 2005 | 08:31 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
yeah maybe over fouled plugs.
I use NGK in my car and motorcycle and they seem to work just fine. I used Bosch Platinums in my Porsche and I did not see a difference...
Old Jul 13, 2005 | 08:41 AM
Mitch C's Avatar
Mitch C
VR
Old Jul 13, 2005 | 09:17 AM
Mr. C's 5's Avatar
Mr. C's 5
Spark plugs will not add HP but keeping them in good condition will prevent you from losing it. I use the +4’s because they’re long life, don’t require gapping and won’t blow out during sustained high speeds. – C.
Old Jul 13, 2005 | 09:34 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I did those +4's in my old 93 LT1. WORST mod ever. Rough idle, bad gas mileage, etc...I pulled them out after a few hundred miles. I then found the PN#'s matched the plugs in my 99 Tahoe so I threw them in there thinking it was just a fluke with the LT1. The Tahoe ran about the same, but the gas mileage went down 2 MPG. Never again.
Don't waste your money.
Old Jul 13, 2005 | 10:29 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I used +4s on my last 2 cars. I use them for the pre-gap and they make the car idle a little smoother IMHO
Old Jul 13, 2005 | 11:08 AM
99 vett babycar's Avatar
99 vett babycar
if Bosch takes out a bigger in in the magazine next month they'll publish a correction saying the plugs add 10 - 12 hp. BS.
Old Jul 13, 2005 | 12:04 PM
SGT. PYLE's Avatar
SGT. PYLE
It's true! And the hood seal will add 15hp for a total of 21-23RWHP. LOL!!!
Old Jul 13, 2005 | 01:20 PM
1stC5weiss's Avatar
1stC5weiss
I use Plat +4's, I've had now problems...I agree you wont see any HP gains, but they seem to run smooth and have a long life. I got them on sale so they weren't really that expensive. Overall I'm satisfied. (However, I did upgrade the wires to MTD 8.5mm supers)
Old Jul 13, 2005 | 01:38 PM
vetteamerica's Avatar
vetteamerica
I installed Bosch plugs and the car ran terrible, replaced with NGK and all is good now...
Old Jul 13, 2005 | 02:03 PM
jim2527's Avatar
jim2527
Didnt the mag substantiate the it themselves?
I have them in my 2003 C5. Idle is smoother and they last a long time. It was the best mod I did to my '94 C4. Not the exhaust wires or intake. It was the +4's.
Old Jul 13, 2005 | 03:24 PM
IFLUBYU's Avatar
IFLUBYU
Been running the +4s in the c5 for 3 years now. Zero issues. Can't swear to any power gains, but they were much better than stock. 400rwhp for a cam only, and a mild cam at that, I sure ain't losing any power with them. Running them with Taylor wires and koolsox.
I liked them so much I put a set in my 90 Jimmy (full-size), OMG, what a difference.
Not an expert, just my $.02... Good Luck!
Old Jul 13, 2005 | 03:27 PM
ArKay99's Avatar
ArKay99
You are very wrong. You will not see ANY gains unless you use them in combination with the throttle body bypass.
Old Jul 13, 2005 | 05:33 PM
lost's Avatar
lost
Actually Ive seen significant increases on dyno tests with Denso Irridium plugs on forced induction applications.Doing a google search and there seems to tons of evidence that these plugs are good for at least 1 hp over even the vaunted ngks in normally aspirated applications.No I'm not going to dump my $6 ngks for $12 Densos
Old Jul 13, 2005 | 06:39 PM
Mike Mercury's Avatar
Mike Mercury
for me, Bosch Plat+4 = missing and hesitation (I was using the stock wires though)
I then put in the Delco Iridiums and it hummed like a precision instrument.
Guy at AutoZone kinda laughed at me when I returned the Bosch +4 plugs... saying that the Bosch is too cold for a stock LS1 motor, and that changing to bigger diameter plug wires is a must with them.
I would of never believed this unless I had seen it with my own eyes.
To Bosch Plat+4 = HP increase
