Rear sway bar bolt threads stripped!
Apparently whoever took this bolt out last time didn't take the time to get it back in correctly. When I took to bolt out I pulled whole circles of threads out of the carrier. At least a quarter of the threads are completely gone, and the rest look to have damage to some extent.
So, I have two questions:
1. What causes this problem? I've never seen both sides suffer this on the same car. It's almost like the fasteners are torqued right to the edge of what the aluminum can take, from GM.
2. I think I'm going to have to helicoil this fastener, so can you tell me what the size is of the fastener?
TIA, and have a good one,
Mike
I told him to just snug it and I'd torque it at home.
Don't know the size of the bolt but a thread gauge can fix that easily. In a pinch, I take one with me and match it at the parts store.
Best of luck in the fix.
I'd believe that, except that I've seen it now on multiple C5s on different sides. In at least two cases (my car being one of them), I believe they had never been off the car.
And, considering how tight I've seen things be when coming off for the first time, I do agree they're probably overtightened, but I think it's happening at the factory.
Yeah, as far as running through the thread pitch exercise goes, I can do that, I was just hoping someone would know.
Thanks anyway, and have a good one,
Mike
So I took out these bolts, swung the bar down, changed the exhaust.
When I got the swaybar back up, and started the bolts, one went in fine.
The other one on the passenger side went in with way too much torque to get it clamped down. I hope the rear carrier hole isn't stripped if I have to take it off again, but it did tighten down tight.
So mine is messed up also.
Here is the most common fix, as you may know, that hole is drilled much deeper into the x-member than the sway bar bolt penetrates, so you can chase threads deeper into the x-member and simpy get a longer bolt with the same thread pitch and diameter. On race cars that we know the sway bar will be instlled and removed several times, we install studs into x-member and simply use nuts, like the lower connection uses. I think that they are 12mm x 1.75 but I'm not sure as I'm at home.
I had the exact same problem mentioned here, I could easily install the driver's side but for the life of me couldn't get the pass. side bolt to go back correctly. I could barely get it started!
Frustrated because I didn't want to strip the threads on my brand new baby I decided, instead of just forcing the bolt back in I'd get a tap and re-tap the hole.
I lucked out! At Pep Boys they had a device to measure the bolt thread pitch etc. but didn't have a tap.
I went to two other auto parts stores striking out at each.
Finally I headed to Sears and they had it!
This worked perfectly! I really only had to tap a very short distance into the hole, like the first few threads. I sprayed WD-40 into the hole before and after tapping. Then I blew compressed air into the hole to hopefully clean it out afterward.
Once tapped the bolt hand-threaded in perfectly. So, I removed it, put some anti-seize on it, threaded it back in, torqued it to 49'-lbs. and was done!
I've removed it once since, to install z06 Ti's. It removed normally and threaded back in without any difficulty.
The tap I bought was: M12-1.75 from Sears. Cost: $4.99. Well worth the purchase ahead of time if you are thinking about doing a rear swaybar upgrade. No sense screwing up the threads if you don't have too!
..rickko..
One quick note - the torque value for the swaybar upper clamp bolt is 49 lb. ft. It's 70 lb. ft. for the lower clamp nut.
Thanks for correcting that. I'm going to go back and edit that into my post. I'm sorry I didn't catch that.
I hate making mistakes like that.
..rickko..
I had the same story as rickko - good save!
..rickko..
Thanks for the info, I'm looking to upgrade the anti-sway bars sometime soon so I'll get a tap when I do
Oh, and later in the day I installed an exhaust system on a '04 coupe, no problems whatsoever.
Have a good one,
Mike
