Headlights won't pop up
Old Jul 16, 2005 | 07:13 AM
sacsrpc's Avatar
sacsrpc
Default Headlights won't pop up
I am having an electrical issue. Both headlights willnot pop up. They turn on but do not pop up. Also, the dash and center console lights go out when I turn the headlights on.
I thought the problem might be in the headlight multi switch so I replaced it but that did not solve the problem. Anyone have any ideas of what else to check?
Old Jul 16, 2005 | 06:20 PM
jdmvette's Avatar
jdmvette
Night Owl for life
did you check the 10A fuses yet?
Old Jul 16, 2005 | 10:05 PM
sacsrpc's Avatar
sacsrpc
Yep, already checked both fuses for the headlight motors/. They are fine.
When I pull the key from the ignition my dash and center cluster lights come back on for exiting the vehicle.
Old Jul 17, 2005 | 03:19 AM
00Veech's Avatar
00Veech
have you checked the little module inside the bumper on the pass side?
Old Jul 17, 2005 | 09:28 AM
1bernie1's Avatar
1bernie1
I had a similar problem. Lights would not pop up intermittently. Found low voltage and loose battery connection. No problems since replacement battery bolts.
Old Jul 17, 2005 | 04:55 PM
B84RADR's Avatar
B84RADR
I'm having the same intermittent issue where one or both lights get lazy.
Old Jul 20, 2005 | 01:12 PM
sacsrpc's Avatar
sacsrpc
Ok had some time to look at it last night.
My headlights still won't pop up. I also noticed I do not have any rear lights (but I do have break lights) and no parking lamps (but Turn signals do work).
Does the module inside the bumper control these items? I am really at a loss on this one. Might be time for me to invest in a set of service manuals.
Old Jul 21, 2005 | 04:49 AM
1bernie1's Avatar
1bernie1
You can get a subscription to an online service manual at ALLDATA.com for about $25/year.
Old Jul 21, 2005 | 01:11 PM
catfish2's Avatar
catfish2
Keep us up to date on the remedy. I have been having some of the same gremlins and don't even know where to begin.
Old Jul 21, 2005 | 02:00 PM
DickieC.99's Avatar
DickieC.99
From your last post I couldn't figure out if you checked your battery connections, or not, per 1bernie1's suggestion. It sounds too easy a fix at first, I know. But I found a loose battery connection to be the problem when my lights would turn on but not pop up.
Old Jul 21, 2005 | 02:42 PM
sacsrpc's Avatar
sacsrpc
I checked the voltage on the battery and I have 13.8 volts. I will double check the connections tonight.
Did you guys with the battery problems have any other problems (like the dash lights and no drl's too?) or only a problem with the headlights popping up?
Old Jul 21, 2005 | 02:54 PM
t56gen3's Avatar
t56gen3
I'd also check all chasis grounds. A non-grounded relay will cause you problems.
To Headlights won't pop up
