What is the normal or average oil pressure on a 99 6 Speed Coupe at idle? Mine is 18 psi @ 750 rpms. Is that normal, I have 58,000 miles and stays in the garage most of the time. Oil Life reads 62% so I dont know. I smell antifreeze every once and a while and my temp is 230 degrees at idle on a hot summer day. Can anyone help me on this? I have already replaced the oil sending unit on the back of the motor.
thanks for input, yea if could find that link it would be great! Im thinking bad motor, still under warrenty, or maybe a possible rebuild (modified) Let me know something.
What oil do you use? If you are using Mobil-1, try switching to Amsoil 5W-30 or German Castrol 0W-30 and see if you get a little more pressure. Mobil-1 is a good oil, but at 100 degrees C it has a viscosity of 10 Cst, which is at the bottom of the range for a 30 weight oil. Amsoil or German Castrol are just under 12 Cst which is at the upper end of the range. You might find a little higher oil pressure with these oils. Also, what oil filter do you run. Some are more restrictive than others, so your choice of oil and filter may play a small role in you final pressure. Of course if there are mechanical issues, than more in depth corrections would be required.
I am using mobil 1 and fram oil filter. I think the fram oil filter is contributing to the low pressure and the heat too, Its been in the mid 90s all week. I cranked it up last night and it had 40 psi cold. So I think mechanically its OK, But Ill try Amsoil and a better filter and see if that helps. Thank You very much for the very helpful information.
