will this mod hurt my C5...?
Old Jul 18, 2005 | 05:17 PM
red97vette's Avatar
red97vette
Default will this mod hurt my C5...?
i didnt get a gasket with my blackwing, so im useing a small cloth..
i posted in C5 General...
http://forums.corvetteforum.com/show...6&forum_id=103
what do u guys think? will it be ok for a little while, until i can get the gasket?
red
Old Jul 18, 2005 | 05:25 PM
hightest's Avatar
hightest
No way!
If for some reason that cloth gets sucked up inside your engine, you could do some real damage.
The blackwings do not come with extra couplers. I used the factory coupler on mine.
Old Jul 18, 2005 | 05:40 PM
red97vette's Avatar
red97vette
Another question...
Whats the point to the "reset" button thats on top of the Blackwing? what the correct procedure to useing it...
i didnt get any instructions with mine..
red
Old Jul 18, 2005 | 05:43 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Originally Posted by hightest
No way!
I agree 100% ! I also used stock rubber coupler to mount Blackwing to MAF...do you still have yours? cloth may also cause false readings from MAF causing computer to compensate for difference in airflow...in my opinion ...get rid of cloth...soon
Old Jul 18, 2005 | 05:55 PM
3Vettes@Home
Cruise-In V Veteran
Originally Posted by red97vette
Another question...
red
when it changes from "green" to "orange" means it's time to clean/wash/re-oil filter....off the car, filter has to dry completely before re applying oil and re-installing in car
Old Jul 18, 2005 | 05:57 PM
red97vette's Avatar
red97vette
My rubber couppler was attached, and made of one piece rubber that also connected to my intake shroud thing.. so i couldnt just take it off.. i donno if its cuz mines a 97...?
Old Jul 18, 2005 | 06:02 PM
3Vettes@Home
Cruise-In V Veteran
There should have been a rubber coupler between your original air cleaner and MAF, this is the coupler you use where you have the cloth installed
Old Jul 18, 2005 | 07:20 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
He'll need a step-down adapter, since Blackwings come ready to mount to 2001+. MY below that, need an adapter / reducer.
And please don't drive the car like that until it's fixed!
Old Jul 18, 2005 | 07:23 PM
red97vette's Avatar
red97vette
im going to try and go to lows/homedepot and see what i can find.. other than that..im screwed, i dont have my stock airfilter...
Old Jul 18, 2005 | 07:25 PM
97 BBB C5's Avatar
97 BBB C5
posted a reply to you in the general section, but idle issues and such is probably from your MAF, and like other said...Get rid of the cloth...NOT good! You need to clean the tiny wires on the MAF with alcohol and q tips, being very gentle and very careful NOt to break those tiny sensor wires. This WILL make a big difference in throttle response and help any idel issues hopefully you are having...trust me it will help and should be regular maintenance you do as well as when the sensor wires get junked up or dirty it affects throttle response and idle...JUST BE CAREFUL! Hope this helps you and let us know.
Dave
Old Jul 18, 2005 | 07:38 PM
3Vettes@Home
Cruise-In V Veteran
Many of the vendors here that sell the Blackwing also sell this coupler that you need, check with the vendors on the sidebar on the left of the screen like L.A.P.D etc. most all used to carry them.
To will this mod hurt my C5...?
