Changed my blower motor because I could not handle the southern heat anymore. The car had no problems before, and now it doesn't want to start and after I get it started it wants to die. Then when I cut it off it tells me to SERVICE ENGINE SOON!!!! The only code I pull is BCM 40 B2592. I am not home at this time so I do not have my code list. What could be going on?
I would have to assume you possibly dislocated something on the BCM, which is in the area you were working in.. I'd go though / re-seat the connectors in the general area.
The Code reads Column lock/unlock Drive(B). The code relating to the change of the blower motor I would think not. It my be unrelated because the blower motor is a simple exchange that does not have any other equipment / electrical connectors to fool with to remove motor.
