p1416 air injection sys code, anyone ever get this
Old Jul 20, 2005 | 11:30 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default p1416 air injection sys code, anyone ever get this
air inj. sys. looks ok, the code is coming up after my 25minute hiway commute on the way home when i get into slower suburban traffic, that's the only time the code pops up, at least it's consistent; i clear the code which also turns off the mil light, anyone have a fix for this? i've got the fix for the fuel gauge=remove pass. side sender and clean w/ brake cleaner and q-tip
Old Jul 20, 2005 | 11:46 PM
edensknight's Avatar
edensknight
Hi Connecticut,
Greetings to you, my friend. Please refer to the following link where I list an explanatory post that specifically answers your dilemma: http://forums.corvetteforum/showthre...199&forum_id=1. However, if for whatever reason the link does not function, merely refer to the C5 Tech Section (first page) for today's date. And, simply scroll on down to a post listed by fellow CF member "Grumpy" titled "Code 1416". This response should prove helpful to you.
Best Wishes,
Eden
Old Jul 21, 2005 | 12:41 PM
ericdwong's Avatar
ericdwong
Passnger side air check valve. Its buried behind the intake manifold, The part is cheap $10-15ish. I tried to use the compressed air and brake kleen method to stick unstick it but its still stuck.
To p1416 air injection sys code, anyone ever get this
