How to repair broken ground stud???
Old Jul 21, 2005 | 06:45 PM
muncie21's Avatar
muncie21
Default How to repair broken ground stud???
I broke off the ground stud next to the battery. Any ideas on how to repair this? Can I just ground the wires to the negative side of the battery?
Old Jul 21, 2005 | 07:24 PM
Z11409's Avatar
Z11409
Or--attach jumper wire to neg cables and attach to ground stud up by headlights--Or--drill hole and reattach eyelets with a large self tapping sheet metal screw
Old Jul 21, 2005 | 07:51 PM
muncie21's Avatar
muncie21
Good suggestion. I attached a jumper and connected the wires to the ground by the headlight.
Thanks!
Old Jul 21, 2005 | 09:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO! Drill the frame and install a self tapping screw! That works best. You want that wire to be as short as possible. That is your MAIN ground wire fron the battery to the frame!! Here is what I did to repair mine when it broke off: This is the ground stud behind the rear wheel. G-401
I have a picture of the screw and a picture of the repair on the fromt frame rail G-101. Sene me your e-mail address and I will send them to you.
Bill
Old Jul 21, 2005 | 10:54 PM
muncie21's Avatar
muncie21
Good point regarding the length of the ground Bill. Guess I'll be busting out the drill tomorrowl.
To How to repair broken ground stud???
