I was thinking of converting the existing air pump in front of the driver front wheel to run at all times (switched 12vdc) and plumb the crankcase to that pump. Then fix the accompanying codes, of course.
Pulling a vacuum in the crankcase does seem like a good idea to me, but it leaves me with a question. In normal operation, the crankcase doesen't see much pressure in it, either positive or negative. The PCV system applies a slight vacuum to suck put any blow-by that got past the rings, leaving the pressure inside close to atomspheric (I'm guessing). The engine's gaskets are designed to keep the engine's juices inside, not hold pressure. Will they hold up, or do different gaskets have to be used? And how much HP does this pump use up, anyway?
Normal operation will see 2-3 PSI crankase pressure and with large inch stokers, much higher. 5"-10" of vacuum is enough to offset the positive pressure and help seal the rings.
I've tested this product for nearly a year and the gaskets and seals are fine. If you have an application that will be pulling plus 30", then you need double lipped front and rear seals. We sell those as well.
The pump consumes 1-2 Hp to operate but will pay that back.
Randy, thanks...we've been working on this for awhile and put over a year R&D and 10k miles of testing to make sure it is reliable, quality built, rugged and able to deliver on the race track as well as the street.
Hi Robert,
Not a bad idea but once off idle there isn't sufficient SCFM from that air pump.
And, to give you an idea of the electrical power required to maintain 14" of vacuum @ WOT, you need about a 1 HP DC motor and that will pull over 60 amps!
Charlie
Wow, what kind of CFM are you trying to evacuate? I know it’s the vacuum that consumes most of the power, but the CFMs certainly add to it.
Looks like a well thought out setup!! WHere would it be mounted on a S/C application like mine?
Charlie,
This would be great to help evacuate excessive blowby on a FI motor. Any plans for an alternate mounting location to coexist with your centrifugal kit?
